From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Not absolutely certain on the 98.
I can in my '03.
If you can, the switch is located in the glovebox and a little warning indicator is on the console. The switch only works on the passenger airbag. Not sure you'd want to shut off the driver airbag, especially during track events. Might come in handy.
The '98 did not come with a passenger side air bag cutoff switch from the factory - that feature came out in mid-2000 model year. You can however buy a kit that will enable you to cut off the airbag on the passenger side. It is available from your dealer.
