Head unit removal
Old Jul 30, 2007 | 08:39 PM
jarsdad1's Avatar
jarsdad1
Default Head unit removal
Console and accessory panels removed. Is there a secret to releasing the connectors on the back of the head unit? Looking at the replacement unit, only the connector on the pass side looks like it is clamped on. The other connector and the antenna cable look like they can just be pulled apart. I broke a connector on my daily driver, so I just want to make sure I do this right. Thanks.
Old Jul 30, 2007 | 08:42 PM
Z06Electron's Avatar
Z06Electron
All the connectors, save for the antenna will have a tab to push down in order to release from the head unit.
Old Jul 30, 2007 | 09:02 PM
ledsnake's Avatar
ledsnake
Thats how mine was little push tab on all connectors.
Old Jul 30, 2007 | 09:04 PM
mcgilles's Avatar
mcgilles
the antenna cable on every car I've ever seen is just a pressure fitting, it pops right out with a bit of force. Just pull strait out on it and not to the side or you might break something or bend it.
To Head unit removal
