Pre-detonation
Old Jul 30, 2007 | 09:06 PM
rockynei's Avatar
rockynei
Cruising
Default Pre-detonation
I have had a pre-detonation problem at high RPM's. I tried the Granatelli MAFS and got check engine lights. I read that the Granatelli is junk. I believe it. I knocked the honeycomb out of my factory MAFS and am wondering if that is why I am getting pre-detonation. I am putting an MSD Blaster (8 coils) pack in. Did I make a mistake by knocking the honeycomb out?????????
Old Jul 30, 2007 | 11:53 PM
Virtual Geezer's Avatar
Virtual Geezer
I'm not sure what you mean by 'pre-detonation.' Do you perhaps mean pre-ignition? If so, you have a very serious problem and you will destroy your engine quickly. Pre-ignition means fuel is exploding BEFORE piston travels past top dead center. You can imagine the devastation -- piston is traveling upwards and gets prematurely slammed back down by the ignited fuel charge.
Perhaps you mean detonation or knock.
Old Jul 31, 2007 | 06:20 AM
rockynei's Avatar
rockynei
Cruising
Default pre detonation
Maybe I do mean knock. Do you think the MSD Blaster pack will help and did I do the right thing knocking the honeycomb out?
Old Jul 31, 2007 | 06:27 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
We'll need more information - detonation or knock.
As a noe - the Tech Section may be able to assist more so than General.
Lastly - take the Granatelli MAFS off the Vette and use it for a paper weight
Old Jul 31, 2007 | 07:24 AM
ryoder's Avatar
ryoder
My 98Z28 had a descreened MAF when I bought it. The prev owner must have done it. It pinged when warm from the get go. I never noticed cause I moved to PA for a while. When I got back to FL it started pinging more often. I put EASE diags on it and found the LTRIMs were at 25%. Which means it was running lean. I thought the descreened MAF may be to blame so I bought an unmolested low mileage one for 45 bucks and the problem was gone!
The LTRIMs whent back down to 5% and there was NO pinging.
Old Jul 31, 2007 | 08:40 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I have heard knock referred to as pre-detonation several times before, albeit somewhat uncommonly. The idea is that a detonation occurrs every time a cylinder fires properly -- the controlled explosion that keeps the crankshaft moving. So calling knock "detonation" is a misnomer by this standard. Instead, they call it pre-detonation, as a synonym for pre-ignition.
rockeynei, if you somehow damaged your MAF sensor to a point where it reads incorrectly (but not to the point that it's complete gone) that may be contributing to your pinging. The MAF is partly responsible for the fueling of your car, and if it tells the PCM that less air is entering the engine, the PCM will command less fuel from the injectors. There is logic that gives fueling authority to the VE tables instead of relying on data from the MAF, but only in situations where they disagree substantially on where fueling should be, or during throttle transitions, etc.
Easiest way to tell would be to get someone with a scanner to look at the signal coming from your MAF and see if it's within the expected ranges at idle, cruise, etc.
Old Jul 31, 2007 | 08:49 AM
LRD VDR's Avatar
LRD VDR
Lastly - take the Granatelli MAFS off the Vette and use it for a paper weight [/QUOTE]
Not true.....also makes a great hamster hotel.
Shahram
Old Jul 31, 2007 | 12:04 PM
Brad@RevXtremeAutoSports's Avatar
According to my tuner, if you descreen the MAF, a tune or retune is a good idea. He also said not to buy any of the aftemarket ones, they don't work.
Old Jul 31, 2007 | 05:28 PM
rockynei's Avatar
rockynei
Cruising
Default pre detonation.
I have a BBK intake manifold with an 80MM throttle body. Iridium plugs. MSD Ignition wires. MSD Blaster coil pack. Superchips power programmer and a 160 degree Thermostat. I am wondering if I need to go back to a stock MAF and see if my high rpm's ping goes away. What does any body think about that? Thanks for responding.
To Pre-detonation
