[Z06] Tire Mismatch Question
Old Jul 31, 2007 | 04:34 PM
03SpiralGray's Avatar
03SpiralGray
Default Tire Mismatch Question
I want to put 315 30 18 on the back of my car, will this cause any type of problem as far as handling or interfere with the active handling?
Should I also put a bigger size on the front?
Old Jul 31, 2007 | 08:36 PM
dbaker's Avatar
dbaker
I run IForged Seneka wheels ,F:18X9.5 R:19X10.
275/35/18 up front & 295/30/19 aft.Conti Sport 2's.
It's a good standard daily driver setup.You need to have an inch diff front to back to keep the abs/ah happy.
\db2
Carolina
Old Jul 31, 2007 | 09:11 PM
jbauch357's Avatar
jbauch357
Diameter difference, not width difference is what is going to effect the AH/TCS systems on the car. That tire is almost an inch shorter than the stock 295/35/18, so it has a good chance of throwing things off.
Use the following link for figuring tire specs: http://www.discounttire.com/dtcs/infoTireMath.dos
To Tire Mismatch Question
