Lowering Question!!!
Old Jul 31, 2007 | 07:52 PM
03Z06GUY's Avatar
03Z06GUY
Default Lowering Question!!!
After i lower my c5 (on stock bolts) how soon do i need to get a front end alignment? Can i go a little while? Thanks!
Old Jul 31, 2007 | 08:35 PM
bcseitz's Avatar
bcseitz
I found that my coupe wasn't out that far at all. Mostly more neg. camber. Toe and caster were OK. I ended up pretty much in Z06 spec.
However every car is a tad different. Some cars are more out from the factory!
For peace of mind I would just plan on an allignment. Figure out in advance what specs. you want. Print them off and give them to the guy doing the 4 wheel allignment.
Most Important! Only take your baby to a recommended Corvette allignment shop. Ask around for one.
Bob
Old Jul 31, 2007 | 08:37 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Bob
Good Advice. Also, you will be looking for a 4 wheel alignment, NOT just a front end.
Old Aug 1, 2007 | 12:24 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
I wated 4 days and 30 miles. It was off a pretty good amount.
Get the 4 wheel alignment.
Paul G.
Old Aug 1, 2007 | 09:37 AM
jrose7004's Avatar
jrose7004
I let mine settle for a couple of hundred miles.
Old Aug 1, 2007 | 11:16 AM
SR-71's Avatar
SR-71
How low are you going to drop it? Are you cutting the bushings on the front with longer bolts out back? If your just cranking down the stock bolts I doubt you'll be to far out of specs.
Old Aug 1, 2007 | 02:40 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Me too. But when I did have it done it NEEDED it. $88 tax included, 4 wheel computer alignment in the specs I gave them.
Old Aug 1, 2007 | 02:46 PM
uk_vette's Avatar
uk_vette
So if just lowring front and rear on stock bolts, no cutting bushes, alignment should be pretty "intact"
Any one got the linky for geomety settings?
Old Aug 1, 2007 | 04:43 PM
Glennm27's Avatar
Glennm27
Click ===> C5 Alignment Specs for FE1, FE3 & FE4 cars
Old Aug 1, 2007 | 07:56 PM
03Z06GUY's Avatar
03Z06GUY
I really like the look of sr71's z. Plus he has stock rims like mine. I would like to get as close to his look as possible just not sure how far he went. Gettin it done saturday, alignment on tuesday.
Old Aug 1, 2007 | 08:07 PM
Glennm27's Avatar
Glennm27
From what I can see by SR-71's avatar pic, to match that look, you'll be putting in longer rear bolts and removing the front bolts (or maybe just cutting the bushings up front). You're talking about slamming the car there, NOT just lowering.
Old Aug 1, 2007 | 11:33 PM
03Z06GUY's Avatar
03Z06GUY
Glenn, you might be right. I don't really want to SLAM my vette, just looking for a more sporty look i guess. I also do not want to cut anything! I guess i'll just crank the stock bolts down and see what happens.
Old Aug 2, 2007 | 11:16 AM
gpracer1's Avatar
gpracer1
Get the alignment done soon! I waited a while and forgot about it. My car was a little twitchy on ruts, bumps, etc. One day I had the wheel tuned all the way in the driveway and I noticed the inside of the one tires was wasted almost to the cord!!!!!!!!!!
Got an alignment the next day and it drove perfect.
Old Aug 2, 2007 | 12:02 PM
SR-71's Avatar
SR-71
http://tinypic.com/view.php?pic=5y03ew7
Cut bushings on the front and bolts in the back. Since this photo I've actually raised the back a hair to match the front better.
Old Aug 2, 2007 | 12:35 PM
thedonn007's Avatar
thedonn007
I don't think that the link is working, at least I do not see a picture of a corvette when I click it.
Old Aug 2, 2007 | 01:27 PM
SR-71's Avatar
SR-71
Photo site was messed up I guess....try the link now..
Old Aug 2, 2007 | 04:21 PM
MSO4's Avatar
MSO4
I'm trying to decide how much to lower my car.
Can you tell me how much gap you have between the tire to the top of the outer fender edge? Do you have significant problems with clearance when driving or in the parking lots?
Thanks.
To Lowering Question!!!
Old Aug 2, 2007 | 04:56 PM
SR-71's Avatar
SR-71
I have 1 1/4 inch between the top of the tire and the fender. Pulling into parking lots and places that have an incline the front air damns will touch down some. You'll just have to hit them at an angle. Other than that I dont have any problems.
Old Aug 3, 2007 | 01:32 PM
garyko's Avatar
garyko
Can anybody point me to the thread for lowering an 02 z06 on the stock bolts?
thanks
gary
Old Aug 3, 2007 | 01:36 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Its recommended after you drive it for few days
