Larger Wheels, why?
Old Aug 2, 2007 | 01:11 PM
Vega$Vette's Avatar
Vega$Vette
99.9% for looks.
FYI NASCAR runs 15" wheels.
Old Aug 2, 2007 | 01:17 PM
When I bought my 19/20 setup, I did it mainly for looks- the tire widths on the front were the same as stock and the rears were a little bit bigger. Really didn't notice any difference in handling or ride.
Old Aug 2, 2007 | 02:38 PM
DefenderC5's Avatar
DefenderC5
Originally Posted by Halfway
you clearly have no idea what you are talking about...at all.
I was going to rebute, but its not worth my time. Get informed.
Then maybe you should inform me if you are so well versed? I do not disagree with anything you stated in your earlier post. I fail to see where the huge disconnect is when you also stated larger wheels are for looks.
Maybe I should reiterate my statement. Larger diameter wheels are for looks only. You can put a lower profile tire on ANY diameter wheel for better cornering. The reason of getting a larger diameter wheel only to put on a lower profile tire is purely for looks.
You may not have the time to rebute, but you had the time to post to tell me so.
