[Z06] Burnout Advice
Old Aug 3, 2007 | 01:22 PM
thraka's Avatar
thraka
Default Burnout Advice
I am looking at doing more serious drag racing. Among other things, I am wondering if folks can tell me the best SAFE burnout method to heat tires. Ideally, I want my front brakes engaged when I do it. Any suggestions?
Old Aug 3, 2007 | 01:47 PM
jbauch357's Avatar
jbauch357
I'll let a more experienced (at drag racing, that is ) forum member explain the proper technique...
Thanks Ranger!
http://www.rangeracceleration.com/Burnout.html
Old Aug 3, 2007 | 02:01 PM
Ranger's Avatar
Ranger
Thanks, jbauch357.
Suggest folks learning the burnout procedure consider doing some parking lot practice before heading to the track. The method for making a pseudo burnout box is covered at the lend of the write-up at the link in post #2.
My burnout procedure is shown at my site under Driver Cred videos
C6Z on DRs and
C6Z on stock tires
Ranger
Old Aug 3, 2007 | 05:34 PM
Higgs Boson's Avatar
Higgs Boson
If you are going to do some serious drag racing I assume you will be on slicks and have installed a line lock? I haven't read Rangers advice but I assume it is
Street tires - pull around water, 2nd gear, rev it up and let the clutch out and spin the dirt off the tires briefly. pull to line.
drag radials - pull around water, back into water slowly, pull out slowly to just at the edge of the water, 2nd gear, and with the left portion of your left foot on the brakes lightly and the right portion of your right foot on the gas, bring the revs up to somewhere around 3-4K and let the clutch out while modulating brake and gas. Use your ankle to do this. Keep just enough brakes applied to keep the car from moving forward and enough gas to maintain the RPMs. let it spin until there is smoke and let pressure off the brakes and maintain small pressure on the gas so you roll forward and the tires hook. pull to line.
If you have a line lock you don't have to work the pedals. just apply pressure to brakes, flip line lock switch on, let off brakes, rev it up, let out clutch and warm the tires as above and then flip the switch off to release brakes. pull to line.
don't forget to turn off traction control!
Old Aug 3, 2007 | 06:47 PM
u4ick's Avatar
u4ick
Here we go........
Old Aug 3, 2007 | 07:50 PM
thraka's Avatar
thraka
Ranger has his own site now? Sweet, that should come in quite handy!
As for DR's versus street tires, line lock, etc., that's part of the decisions I am making right now. Trying to get my C4 fixed so I can possibly do just that, and I am thinking about whether I want to reconfig the Z06. What I don't want to do is be switching tires all the time, so it will depend on if I get my other ride in shape as to whether want to put DR's on.
Old Aug 3, 2007 | 08:08 PM
Higgs Boson
Originally Posted by u4ick
Here we go........
Old Aug 3, 2007 | 08:10 PM
Higgs Boson
Good luck! The different brands of DRs are pretty different so you might find one that fits your needs if you want to drive on them a lot.
In order from good daily driver to better traction they are basically (IMO of course, lol): Nitto, BFG, Mickey Thompson....
Old Aug 3, 2007 | 08:34 PM
Ranger's Avatar
Ranger
As for DR's versus street tires, line lock, etc., that's part of the decisions I am making right now....
Hi thraka. If you'll spent a few minutes reviewing the videos on my site together with the burnout procedure page, you can see that there is no need for a line lock.
Some folks express concern about brake wear....I put 350 burnouts on my 2002 Z06 plus 30K street miles, original brakes were still fine and remain original with another 20K miles by subsequent owners.
The quality of the burnout was fine too; my 60' were among the lowest.
Ranger
Old Aug 3, 2007 | 08:47 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Ranger.....thanks for your contribution to the forum.
Old Aug 3, 2007 | 08:53 PM
Ranger's Avatar
Ranger
Thanks, Tact. Always happy to assist.
Ranger
Old Aug 3, 2007 | 09:23 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
You do not really need a line lock.
Old Aug 4, 2007 | 01:50 AM
u4ick's Avatar
u4ick
Ranger
How did you manage original brakes for that long?
I know I'm hard on tires, but never really considered my self hard on brakes, granted I've had to slow down pretty hard from 140mph a "few" times, I am in definate need of new pads and rotors up front and I have almost 27k now.
You've had to slow down from 110+ at least 350 times...........did I miss read you comment?
Old Aug 4, 2007 | 05:19 AM
Ranger's Avatar
Ranger
Brake life depends on driving style and venues chosen. I've not had to replace rotors or pads on any of my Corvettes. The 2002 is the extreme example because it had 350 burnouts and track passes. But on the street I drive fairly conservatively. I also get pretty good tire mileage.
Ranger
Old Aug 4, 2007 | 11:40 AM
Higgs Boson
This post is not meant to contradict or argue. It is just my view that you should use the right tool for the job. No, you don't NEED a line lock. But you said you want to get serious about drag racing.
You can remove a bolt with pliers it you want. But the right tool is a socket or wrench. Yes you can do a million burnout using the footbrake method but the right way is with a line lock. This is only based on your word, serious. I wouldn't put a line lock on my Corvette.
To Burnout Advice
