I had something similar from what I can tell on the pics, mine was tiny small etched marks. I think it was from sprayed brake/clutch fluid. Let me know how it goes....
I had a problem that was very much like you described. The spots were like 'non shiny' opaic color (MY). I had my favorite body shop light sand and buff out. It is a clear coat issue, but it was not determined what caused the problem. Also, after the sand/buff, no further issues (1.5 years so far). Good luck!
I have similar spots but the hood has been partially repainted as well. I'm going to be hitting it with some 3M rubbing compound to buff out some paint runs, over spray and those spots.
Iven been cnonsidering trying the claybar. Ive never done it and I am worried about the outcome.
After reading the procedure I believe I can do it okay...
I may try that first.
I was going to try clay bar too because I just had it detailed from a good place here. I went back to show them my chemical water spots (from sprinklers) and they offered to clay bar it for me. So if for some reason you don't want to do it yourself you can bring it in to a detailer to clay it for you. I will probably wind up getting my own and doing it because I don't think they did a very good job at it.
could be oxidation from something that is acidic, ex acid rain, bird crap, or bugs that have been left on for a while, if the clay bar doesnt work just sand with some 2000 or lighter some places sell 2500 grit or even 5000 grit paper, that will be alot easier to get the sand scratches out when you buff it, hard clear tends to let the scratches die back. hope that helps good luck
Just so that I am clear... Sand down the clear with 2500+ Sand paper? Then re clear?
Dude leave the sanding to the pros, I wouldnt mess with that cause you could mess it up even worse, clay bar should take care of it just remember to use plenty of the "lube" (spray stuff thats in the kit)
