Dose anyone have any info on ways to eliminate wheel hop when launching at a drag strip? 2002 stock Z06 launching at around 2500-3000 rpm with factory tires and 35 psi, the car shook pretty hard.
What type of suspension mods are worth investing in to help eliminate this issue?
Thanks!!!!
Wheel hop can be avoided by minor driver technique adjustments.
(1) reduce the rear psi to 26-28 hot.
(2) use the three element launch I describe here: General Launch Techniques
(3) it is especially important to squeeze the throttle rather than stab it.
