skip shift eliminator
Old Aug 4, 2007 | 05:37 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Default skip shift eliminator
can i just unplug the solenoid w/o installing the cags eliminator piece? My white plastic part won't fit for some reason, even though it's the right year. done this mod before, this one isnt cooperating. thanks...
Old Aug 4, 2007 | 06:05 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Anyone? While I've got the car raised...
Old Aug 4, 2007 | 06:12 PM
Mick_C5's Avatar
Mick_C5
dont know for sure but if you do leave it disconnected you may want to make sure moisture and dirt cant get into the connectors. i have one lying around here it`s for a 03 you can have it if you want.
Old Aug 4, 2007 | 06:15 PM
oaks99's Avatar
oaks99
i do not believe you can leave it unplugged , if you could why would they sell the cags . but i have not done this to my vette .
oak
Old Aug 4, 2007 | 08:16 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
It will probably throw codes on your DIC if you leave it unplugged.
Old Aug 4, 2007 | 10:12 PM
Mike Mercury's Avatar
Mike Mercury
are you certain you are looking at the correct plug? I seem to remember there were a couple of available electrical plugs in that general vicinity... but only one was for the CAGS.
Old Aug 4, 2007 | 10:19 PM
Slotcar's Avatar
Slotcar
Sorry I didn't see this earlier. If you leave it unplugged you will get a check engine light and the DIC will throw a code. You need the resistor to "fool" the computer into thinking the selenoid is still doing it's thing.
Old Aug 4, 2007 | 10:28 PM
C5naples's Avatar
C5naples
Old Aug 4, 2007 | 10:53 PM
GrayC5's Avatar
GrayC5
To my knowledge, the CAGS connector is the same for all C5 years. I think they may have changed though for the C6. See if the following will help:
HOW TO install the CAGS eliminator on your C5
Good luck.
Old Aug 4, 2007 | 11:55 PM
That's what I am thinking. The CAGS eliminator should fit on the connector just fine - I know mine does. Make sure you are working with the right connector on the upper driver's side of the tranny.
Old Aug 5, 2007 | 12:38 AM
Halfway's Avatar
Halfway
St. Jude Donor '06
110%
Old Aug 5, 2007 | 01:05 AM
Itallian33's Avatar
Itallian33
This is an easy mod to do. If you don't feel like spending the $20 for the eliminator and are handy with a soldering iron, just disconnect the wires from the tranny and add a 2.2k ohm resistor in line(about a dollar at radio shack). We use delphi connectors at work so i just made my own eliminator. Put it on and it has been working for 6 months. PM me if you have any questions about how to do it.
Jason
Old Aug 5, 2007 | 02:53 AM
Autobot's Avatar
Autobot
Jason
When i was going to put mine in I was going to make my own as well, but couldn't get one of the delphi plugs. Anyways in my research I was told to get a 2200 ohm resistor, which I got but when since I couldn't get the right connector I got a premade one.
Anyways, when I measured the resistance on that one I got something like 20 ohms, anyone know where the 2200 ohms comes from, or does anyone have a purchased one and can measure the resistance?
Old Aug 5, 2007 | 03:10 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
There ya go...was trying to put it into a plug on the pass side...
Old Aug 5, 2007 | 03:23 PM
65GGvert's Avatar
65GGvert
Bet while it was unplugged, the back up lights didn't work.
Old Aug 5, 2007 | 11:39 PM
Slotcar's Avatar
Slotcar
Hey Autobot,
I'm not the expert on this but I listened to those who know! When I got a check engine light, my DIC threw a code indicating that the skip shift selenoid was "bad". Well, the CAGS eliminator resistor was not stout enough and burned up like a roman candle. I just popped the end off and soldered a 2.2K resistor in it's place and it has been fine ever since.
To skip shift eliminator
