A/C Troubleshooting
Old Aug 5, 2007 | 10:22 PM
IDM's Avatar
IDM
Default A/C Troubleshooting
Hey team,
Since I purchased my C5 a few years ago the a/c has been questionable. About a year ago I had it pressure tested and they said there were no leaks but that it was low on freon. Had it refilled and 125 later I was out of there. Didn't notice much difference from it being filled. Now after the winter has passed I tried to use it this year and it absolutely blows only hot air out. It's better off to put the windows down in 95 degree weather.
Any ideas as to where I can begin? Are there differences in 97-04 a/c parts if im to try to find some lightly used parts?
Old Aug 5, 2007 | 10:30 PM
DGW's Avatar
DGW
Easiest fix could be cleaning the evaporator, the radiator looking thing right above the front air damn -- just poke your head under your front plate holder and take a look, you can find everything from cig butts to rodents. Clean it out with a pressure washer, or just hose and nozzle, not a stick(it will bend the vents) Other than that, if it really starts acting up it could be the vacume lines from the back of the intake manifold to under/behind the battery, 'specialy if it is the stock battery....
Old Aug 5, 2007 | 10:34 PM
Plasticfan's Avatar
Plasticfan
Sounds like there was a leak but the first shop couldn't find it. Refrigerant does not just disappear, it either stays in the system or it leaks out. Try another shop. There are many types of leak detectors and dyes that can be used, some better than others.
Old Aug 5, 2007 | 11:01 PM
Itallian33's Avatar
Itallian33
A couple of things to check.
Does the compressor kick on? - you can see the pulley on the compressor will start to turn when the clutch on it engages.
If your compressor is working the ac line beside your exhaust on the passenger side will be cold enough to condense water.
Does your outside air temp read right?
Those are some good starting points
jason
Old Aug 6, 2007 | 10:55 AM
IDM's Avatar
IDM
The evaporator is pretty dendted up and filled with rocks. I just replaced the radiator when it cracked. I tried to clean it out with a brush and got a lot of stuff off but it's still old. That may be part of the problem but the A/C is like turning the heat on.
I fixed the vacuum lines a while back behind the intake manifold, I now have a optima red top.
The outside temp sensor was just changed out as well and reads correctly now.
Old Aug 6, 2007 | 10:57 AM
IDM's Avatar
IDM
I agree with ya there. I think there is a leak but also another problem since it wasn't even very cold after I got it refilled. I've been in other corvettes and it freezes you out.
Old Aug 6, 2007 | 12:08 PM
tonio76's Avatar
tonio76
Old Aug 6, 2007 | 04:29 PM
IDM's Avatar
IDM
thanks
Old Aug 6, 2007 | 04:50 PM
coanan's Avatar
coanan
orifice tube in the A/C line could be plugged
Old Aug 6, 2007 | 05:43 PM
bighank's Avatar
bighank
Default Thats the CONDENSER the EVAPORATOR is INSIDE THE CAR
HEY first things first. The Condensor is in front of the radiator. It condenses the freon from the compressor to liquid. The evaporator is inside in the ducting. It allows the freon to expand and go from liquid to gas and in doing so it looses heat.
I just cleaned my CONDENSER with something called NU BLAST. Its triclorethylene and does't need rinsing. You put your front end up like on Rhino Ramps and use the 18 oz aerosol can starting at the top and working your way down the condenser. Don't see any difference since I cleaned it. Before using this I washed the condensor with a hose and spray nozzle and then used a SNOW BRUSH to do a rudimentary cleaning. You could use an air hose and a long spray nozzle too.
I would get an inexpensive set of guages like from Harbor Freight for $39 and then charge the system right. The capacity is just under 2 14 oz cans so from scratch 2 cans should do it. I did replace the valve cores at the charging ports and the orifice tube as they are cheap.
Don't forget to replace the plastic caps over the service ports too.
BIGHANK
Old Aug 6, 2007 | 05:49 PM
DGW's Avatar
DGW
Yep, its the condensor not evaporator, typing without thinking again. My bad....
Old Aug 6, 2007 | 06:06 PM
INaband's Avatar
INaband
CI 7-8 Veteran
Find a better a/c shop that knows what they are doing, my compressor now leaks a little bit, easier to add freon than to replace the compressor, I think.
Old Aug 6, 2007 | 07:20 PM
Old Rotor Head's Avatar
Old Rotor Head
Mine was an easy fix after 3 trips to the alter of the AC God. I had a leaking valve stem. Replaced it 3 years ago, still no problems.
Old Aug 8, 2007 | 10:47 AM
IDM's Avatar
IDM
it wouldnt affect anything if I didnt have a cap over the service valve would it?
Old Aug 8, 2007 | 11:20 AM
ToeBall's Avatar
ToeBall
They don't really leak unless there is an actually leak. I have a 98 Dodge pickup on the factory charge still today.
Old Aug 8, 2007 | 06:50 PM
TTK98's Avatar
TTK98
No, it wont affect the operation. They are there to keep the crap out of the ports so that when you attach your gages it does not push the crap into the system.They are not designed to hold high system pressures,the valve cores do that.
Old Aug 12, 2007 | 12:38 AM
IDM's Avatar
IDM
could it be possible that it's the piece underneath the dash? not the hvac control that you see under the radio but the other pieces? is this easy to get to if so?
Old Aug 13, 2007 | 11:29 PM
IDM's Avatar
IDM
bump anyone know how hard that is to pull out?
Old Aug 16, 2007 | 07:02 PM
IDM's Avatar
IDM
anyone know? can this be done through the radio bezel?
To A/C Troubleshooting
