Programing Alarm
Old Aug 6, 2007 | 01:34 PM
Borracho's Avatar
Borracho
Default Programing Alarm
Hi I am fairly new to the forum and have a quick question. I recently purchased a C5 and the alarma was not working due to the battery. I will be picking up a battery for the alram today but I think I might have to progam it since it has not had a battery for so long.
Question is how do i program the alarm to work with the fob? By the way I do not have the manual. I read the instructions may be listed in there.
Old Aug 6, 2007 | 01:47 PM
R Devil's Avatar
R Devil
Stand next to the car, press the lock/unlock buttons on the fob, hold down till the horn honks.
Old Aug 6, 2007 | 01:55 PM
jay2000's Avatar
jay2000
Key Fobs
There are basically two different kinds of key fobs, and they are not compatible with each other.
97-00, but 00 does not have the Passive Lock feature
01-04
Both remotes use a CR2450 coin type battery. I found replacement batteries at Office Depot. To replace, use a coin to wedge between the seam, and twist.
Ref: Service manual, page 8-747.
Quote:
Originally Posted by vette747
Fob programming
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this step for each transmitter.
Old Aug 6, 2007 | 02:25 PM
Borracho's Avatar
Borracho
thanks for your help.
I love this site!
To Programing Alarm
