Hey guys....I have a problem...I swapped out my stock shifter for a c6 z06 shifter about a year ago. It was a big improvement and was fine until about a month ago. Basically, getting into any gear is not as easy as it used to be but the ones that give me the most problems are 2nd, 5th and reverse. Sometimes it will just pop out of second. And when I go to put it in reverse it will go into 5th. What can be causing this? What is the solution? Please help if you can!
Try re-aligning shifter. Take apart, loosen the two T40 housing shifter bolts, stick in alignment pin. make sure the rear T40 bolt on shift rod is tight, then re-tighten the two shifter housing bolts.
When was the last time you replaced your trans fluid? My MN6 was shifting poorly, my symptoms where not as bad as yours, untill I replaced my trans fluid; I have 64k miles on my 02 Vette.
Another symptom i just thought of......when it is in neutral and i move it side to side...it will stay slightly leaning toward the last direction in which it was moved as opposed to returning straight to the middle
Just a thought, good luck!
Same here. I switched to Amsoil synthetic and all my problems went away.
Anybody have any thoughts about this particular symptom?
