Leaking window wash resivior
Old Aug 8, 2007 | 06:32 PM
chazzvette's Avatar
chazzvette
Default Leaking window wash resivior
I know my window wash is leaking, Ive narrowed it to the float. I took it apart, looks OK. Hoses look OK, no signs of leaking. The rubber seal seems plyable. I cleaned the seal, put it back together and after a few minutes, it driped. Any "tricks" that someone has tryed with the same problem? Can I coat the seal with something? Do I just get new seals? Will that fix it or do I need a new tank. thanks for any help.
Old Aug 8, 2007 | 06:37 PM
c4cruiser's Avatar
c4cruiser
Is the hole in the tank round and have smooth edges? Does the rubber seal fit snugly? Does the float fit snugly through the seal?
I would try to get a new seal if that's possible. It could be that the float and seal are sold as a unit and not separate pieces.
Check the hole in the tank carefully to make sure that there are no rough edges or that the hole is round.
