2nd Column Lock tow in two months...
Old Aug 8, 2007 | 08:30 PM
D2Brewing's Avatar
D2Brewing
Default 2nd Column Lock tow in two months...
I know, I know... CLB is on it's way...
Fri afternoon I had to have my '02 towed for the second time in 2 months. After the first fix, I thought I had some time before the problem came back. At least more than 2 months...
Currently fighting the dealer/GM Customer Service to pay for my 2nd tow... not expecting much.
Old Aug 8, 2007 | 08:57 PM
At least you are getting the CLB. Good luck with GM - probably a losing battle.
Old Aug 8, 2007 | 08:58 PM
rimler's Avatar
rimler
My CLB will be here this Friday
Old Aug 8, 2007 | 09:18 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Old Aug 9, 2007 | 12:42 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Don't expect the CLB to be a cure all for your problems. Many have installed the CLB and still have problems.
Old Aug 9, 2007 | 12:50 PM
YeloFevr's Avatar
YeloFevr
Many?
Old Aug 9, 2007 | 12:51 PM
csexton's Avatar
csexton
Good luck
Chuck
Old Aug 9, 2007 | 12:52 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I put the CLB on my car when I first got it and have never had a problem. I don't know why people keep putting it off until they are stranded
Old Aug 9, 2007 | 12:53 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
May be isolated cases but very, very few. Installed Clb when I bought the car new in 04 and never looked back. Zero problems.
Old Aug 9, 2007 | 01:12 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
the CLB wont work unless you have your PCM re-flashed back prior to any recalls and you remove the faulty GM k-harness that causes BCM to shut down fuel at 2mph
Old Aug 9, 2007 | 01:36 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I don't believe you are totally correct. If you've had the latest recall performed and there are no "current" issues with your car the CLB can be installed and it will work. It is a preventative device which bypasses the faulty signal, thus shutting off your fuel, which is programmed by the dealer during the recall. Working properly the CLB bypasses this faulty signal, thus no fuel shut off and no column lock, but also with the latest recall there should be no locking plate to lock the column. Any questions just call COH.
Old Aug 9, 2007 | 04:17 PM
jzhawk's Avatar
jzhawk
I hope this is true. There are so many conficting posts on ths subject I don't know what to believe. My 98 has had the recall performed. I bought a CLB from COH and have not installed it yet. I had the pull key and fuel shut off once but started right back up. I hate to post the question because this gets beat up all the time. I am waiting for a clear and concise answer befor I install it or if I can install it?
Old Aug 9, 2007 | 04:32 PM
jzhawk's Avatar
jzhawk
Ttt
Old Aug 9, 2007 | 04:39 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Smart man. Then after the 10th you won't have to post a thread like D2 Brewing (Dave) is doing now. I would think GM would HAVE to make Dave whole no matter how many times their fix didn't fix anything. Or at least until February '08.
Old Aug 9, 2007 | 04:43 PM
Tact's Avatar
Tact
If anyone has any questions I would either call COH, read the sticky thread in the tech section, or PM Cscokd and ask his opinion.
Old Aug 9, 2007 | 04:50 PM
Ol'55's Avatar
Ol'55
I'm with you on this one Jack. It must be the "It will never happen to me" syndrome. Or "If it ain't broke, don't fix it". Both make sense until you either get stranded somewhere or read of the many folks in here that get stranded.
Old Aug 9, 2007 | 05:35 PM
ONE BMF's Avatar
ONE BMF
Your time is short -mine did the same thing =2004 Z- had all recalls with locking hub removed,K-harness installed--1 week later it left me stranded(my Chevy dealer mechanic came out to fix it at 10:00pm ) in a parking lot-- i call my friend -send him to my shop to get the CLB from COH i had bought and was looking for clear & concise too -my mechanic tells me K Harneess= SH$T - plugs in my CLB ,starts right up -- 2 yrs no problems since Do it or you will REGRET IT LIKE I DID --This problem will not go away and will undoubtedly Fark you at the worst possible moment -- Murphys Law #1 --THINGS LEFT TO THEMSELVES GO FROM BAD TO WORSEJMHO Good luck bro
To 2nd Column Lock tow in two months...
Old Aug 9, 2007 | 05:41 PM
tellefan's Avatar
tellefan
I didn't think the '04's had this problem. My automatic coupe does not have a steering wheel lock on it. David
Old Aug 9, 2007 | 05:53 PM
ONE BMF's Avatar
ONE BMF
READ MY POST Automatics don't need the lock hub --your tranny is your lock -FED law mandates manual trans must have steering locks for insurance purposes GM had to get an OK from Uncle Sam to remove the lock ring
Old Aug 9, 2007 | 06:57 PM
Marcs c5's Avatar
Marcs c5
never herd of this before. I put the CLB on mine no problems here!
