[Z06] getting drag radials
You can put a 315 Nitto on a 9" wheel. If you tried this with a BFG it would bulge badly which can have many negative affects given the right impact to the tire.
If you want longer clutch life but still very good traction, the BFG 315.35.17 are best, and certainly better than the Nitto in the same size. The BFG need a launch rpm of 3600-4200. And will give about 200 passes before the clutch needs replacement. I've run the BFGs on wheel widths from 9.5" to 12". Haven't noticed any significant difference in logging my results.
On my C6Z, I'm currently running the 315/17 BFGs on C5Z front wheels. They are doing fine for me in this configuration.
Owners are reminded that if you transition to drag radials, there is a new learning curve to ride.
(1) You must do a burnout to heat the tires Burnout Without a Line Lock
(2) Launch procedure needs adjustment General Launch Techniques
(3) You must do clutch fluid maintenance Taking Care of Your Clutch
Ranger
