Winding Sound!?
Old Aug 10, 2007 | 10:55 AM
blkshrk81's Avatar
blkshrk81
Default Winding Sound!?
I can hear a constant winding sound coming from the driver's side rear. It stays at the same pace when I speed up and continues at idle. When I shut the car off it stops. Any ideas?
Old Aug 10, 2007 | 11:07 AM
leave it to beaver's Avatar
leave it to beaver
fuel pump
Old Aug 10, 2007 | 11:17 AM
blkshrk81's Avatar
blkshrk81
I'm getting 423221 when I pull up the codes.
Old Aug 10, 2007 | 11:45 AM
leave it to beaver
what year is your car?
Old Aug 10, 2007 | 04:00 PM
blkshrk81's Avatar
blkshrk81
Ha, guess that would help. It's a 97 model.
Old Aug 10, 2007 | 04:02 PM
R Devil's Avatar
R Devil
It's the pump. Turn up the stereo.
Old Aug 11, 2007 | 12:06 AM
leave it to beaver
I'm still kind of confused where you're getting this code. An OBDII code should be in the range from 0100-1999.
I am still going to go with fuel pump. run it til it quits.
Old Aug 27, 2007 | 01:56 PM
blkshrk81's Avatar
blkshrk81
I don't get any codes for it and it's still running good!
Old Aug 27, 2007 | 02:04 PM
Black_6-Speed's Avatar
Black_6-Speed
Fuel pump. It's normal to have a noisy fuel pump in a '97. Check the weights, measures, etc sticky.
Old Aug 27, 2007 | 09:28 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Yup, fuel pump.
Take off the ds inner wheel well liner and fill the area around the fuel filler tube with insulation. Also line the outside wheel well with HVAC insulation. Should cut the pump noise and some tire whine as well. Ask Mike Mercury about this one. He's helped a lot of members including me. Good luck.
To Winding Sound!?
