Please Help
Old Aug 10, 2007 | 04:16 PM
50vette03's Avatar
50vette03
Default Please Help
I am looking at an 01 coupe. It has the stock wheels and tires (17''-18'')on it and it is lowered on the stock bolts. If I were to put different rims and tires on it what size could I go with? I would like to do 18s and 19s and as wide as possible. But with out them rubbing and still being able to turn.Thanks for your help
Old Aug 10, 2007 | 06:40 PM
C5'S LS1's Avatar
C5'S LS1
19/20 ZO6 Motorsports....No rub unless you hit a big bump at high speed.
Only rubs on the inside center rear fender shroud.
Front rubber stopper cut, rear bolts changed.
