Wheels & tyres comments please
Old Aug 11, 2007 | 07:44 AM
TexasC5Vette's Avatar
TexasC5Vette
Cruising
Default Wheels & tyres comments please
Hi ,going to buy Iforged evolution wheels 18 x 9.5 Front ( with michelin sport tyres 265/35/18) and 19 x 10.5 Rear ( with Michelin 295/30/19)
Need to be sure they will be a direct fit on car, also have Baer Eradispeed discs (with the 14" rears).. Thanks in advance for info
Old Aug 11, 2007 | 11:26 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I run that combo except I run a 275-35x18 in front and a 305-30x19 in back....iForged Equips with Michelin PS2's. No issue. But if you are running an oversized rotor, you might have an issue with the valve stem hitting the brake caliper. Make sure that you check the wheel, dry fit it before the tires get mounted and look at the valve stem clearances.
Trust me - I went through this issue.
