Problem Fixing Headlight Gear
Old Aug 11, 2007 | 09:49 PM
Fixed Roof Coupe's Avatar
Fixed Roof Coupe
Default Problem Fixing Headlight Gear
GOT THE MOTOR-GEAR UNIT OFF THAT LIFTS AND LOWERS THE HEADLIGHT JUST LIKE THE THREADS SHOW, BUT THE METAL PART THAT FITS IN THE GEAR IS ALL RUSTED AND COVERED WITH CRUD. I NOTICE THE GEAR HOUSING HAS WHAT APPEARS TO BE A VENT HOLE IN IT (A CLEAN SQUARE HOLE). HAS ANYONE FIXING THE HEADLIGHT GEAR HAD THIS EXPERIENCE. IT MAKES ME WONDER ABOUT THE CAR. APPRECIATE ANY RESPONSES.
Old Aug 11, 2007 | 11:03 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
pics??
are you referring to the worm gear??
I hope these work..all pics on photobucket and I cant view at work
http://forums.corvetteforum.com/show...=headlight+DIY
Old Aug 12, 2007 | 12:29 AM
Fixed Roof Coupe
I'm trying to get the pictures downloaded. The rusted part is the rotating part with the fingers that fit in the plastic wheel.
Old Aug 13, 2007 | 07:49 AM
c5hunting's Avatar
c5hunting
i just tried (unsuccessfully) to fix my headlight motor, and the worm gear (looks like a screw with larger threads) had lots of amber-colored jelly on it, which I suspect is for corrosion-prevention. My install instructions said to spray the new gear with white lithium grease. I would suggest cleaning the worm gear with wd-40 and a toothbrush, and then coating everything with white lithium greast.
Old Aug 13, 2007 | 08:25 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
http://forums.corvetteforum.com/show....php?t=1767764
Old Aug 13, 2007 | 12:30 PM
road dog's Avatar
road dog
I just got done doing mine the rust colr jell is the type of lubricant they were useing just make sure you clean it all out and install new gear with new lube open your headlights by hand useing the **** at the top of the motor and after your done insalling the headlight assemblys close them and try your headlight switch they should open smoothly
To Problem Fixing Headlight Gear
