Sequential tail lights... anyone?
From: 90% of all Fords are still on the road.....the other 10% actually made it home!
Below is a thread I started last week in which I included a link to a company that sells (IMO) the best product out there. It's a simple "Plug & Play" wiring harness that took me less than 15 minutes to install. If at anytime you decide to remove it, it simply unplugs from your existing socket and that's it......No splicing, No cutting, just plug it in or unplug it!
http://forums.corvetteforum.com/show...l-time+DRL%27s
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Batmbl -
I love mine - I put em in the wifes coupe about two years ago - no problems.
http://www.iammoon.com/c5tech/sequential_install.htm
best regards -
mqqn
best regards -
mqqn
St. Jude Donor '05-'06-'07-'08-'09-'10
I have them. They are ok . I wish the delay between lights was a tad slower. I contacted the manufacture and was told because of the fast blinker the C5 has already that they can't get them any slower.
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Had mine for 2 years+. Love um too...along with the 3rd brake light pulser. The sequentials are just some neat looking bling... the pulser is, IMO, a good safety reminder and I could not care less if it bothers someone behind me - if it does, then it is doing exactly what I want them to..... Draw attention that the car in front IS breaking, so slow your A@@ down and get off my bumper.
I had mine for a little over two years. Loved them. Only problem I have is that if you aren't extremely careful, water can get into the main socket. Since I've taken my taillights out several times (to install the flush tailight kit and change the rubber seal a few times) and apparently didn't get it tucked in just right to avoid water getting into the socket.
The result was that the socket had to be changed out. The sequential harness needs to be changed out too but I've decided against putting it back in.
I've also got the third brake light flasher (had that for about 3 years) and noticed the other night that it no longer flashes for a few seconds and stops (just keeps flashing). Guess I'm gonna have to work on that now too.
I just installed both items from webelectric.com and I don't know how the kits could be any easier and better (unless they sent the torx driver with the kits
). No cutting, no wire splices, just unplug, plug and play. My vote for easiest mod or the year. Only down side is you never get to see how cool they look while you are driving.
