the ac on my driver side will not work it blows out cold on passenger but does not blow out cold on driver i have filled the freon and that is not the problem i have also try resetting the number 27 fuse and that has not worked also any suggestions
I had the exact same problem a year ago as Macadami describes. I took it to the dealer and I was told a HVAC actuator door had gone bad. They charged $700 to repair it. If I recall correctly, the part was in the neighborhood of $200 with the remainder in labor. When asked why the labor was so much, they indicated the entire dash cover had to be removed.
In hindsight, I was not a member of this fabulous forum yet. Had I been, I would have at least attempted the repair first on my own as there are lots of knowledgeable members that could have probably supplied technical advice along the way.
Reason: sp
