Moaning Steering Wheel...
Old Aug 13, 2007 | 09:31 AM
Blue Angel's Avatar
Blue Angel
Default Moaning Steering Wheel...
Guys and Gals, the steering wheel on my '02Z has started "moaning" while turning... sounds like something inside is rubbing. Any pointers before I go tearing into it?
Thanks!
Old Aug 13, 2007 | 10:55 AM
DickieC.99's Avatar
DickieC.99
Common Problem. Take a look at this below..I think this link will still work...
https://www.corvetteforum.com/techti...D=35&TopicID=1
Old Aug 13, 2007 | 11:05 AM
LTVetteVert00's Avatar
LTVetteVert00
Any better pix of where this point of lubrication is located??
Old Aug 13, 2007 | 11:31 AM
jovette's Avatar
jovette
I wish someone would post a better picture...........this is a frequent complaint about this particular "Tech Tip", and I have the same problem. I purchase the can of lithium grease, but am waiting for a better picture / description of exactly where the grease goes, before I go squirting it all over the steering column.
Old Aug 13, 2007 | 02:20 PM
gsadowski's Avatar
gsadowski
Same problem here too. A better picture would help alot...
Old Aug 13, 2007 | 02:21 PM
barrynk's Avatar
barrynk
I have the same problem - I never thought to describe it as moaning, but that is exactly what it sounds like.
The URL for the second picture is misformatted - https://www.corvetteforum.com/techti...s/Steerin2.jpg - It's a little better than the first one, but if someone has a better one, please post it.
Old Aug 13, 2007 | 03:32 PM
omarcoolguy's Avatar
omarcoolguy
those pix where taken when the first corvette came out.....
Old Aug 14, 2007 | 04:14 PM
Blue Angel's Avatar
Blue Angel
Thanks for the info!
The tech tip says the lower bearing... are there two bearings, one high (near the steering wheel) and one low (near the firewall)? How much disassembly is required? Just removal of the knee bolster plate, or does the column need to be removed?
I already have a nice can of white lithium grease, I just need to know where to squirt it!
To Moaning Steering Wheel...
