[Z06] Finally installed a CLB
Old Aug 13, 2007 | 01:13 PM
z28rktec's Avatar
z28rktec
Default Finally installed a CLB
After owning my 02 Z for a year I finally decided after reading all the threads to install a CLB. I got the part from Corvettes of Houston and installation was quick and simple. I sure don't miss hearing the locking pin as you remove the key. It always gave me an uneasy feeling. Hopefully I just saved myself a headache down the road.
Old Aug 13, 2007 | 01:17 PM
DT's Avatar
DT
Good post, reminds me to do mine - I've had a CLB new in a box for ~2 years. Once the column lock happens, it's too late!
I keep planning on a dash/bezel mod which seems like the perfect time to do a CLB install, maybe I'll get all that going soon.
BonestockZ06's Avatar
BonestockZ06
I hear that..
Old Aug 13, 2007 | 02:32 PM
Bigstik's Avatar
Bigstik
So thats what the sound is after I remove the key. I always wondered what it was. How much was the CLB if you don't mind me asking??
Old Aug 13, 2007 | 09:47 PM
z28rktec's Avatar
z28rktec
After shipping it was around $50. When it isn't broken it was hard to justify, but I kept hearing stories about being stranded and repair bills. Helping others not make the same mistakes is what makes this forum so great.
Old Aug 13, 2007 | 10:11 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
believe me...it is the best mod for the $$$$
Old Aug 13, 2007 | 10:46 PM
cdn ws6's Avatar
cdn ws6
The CLB was my first mod, done yesterday.
Old Aug 14, 2007 | 05:53 PM
ZeeOSix's Avatar
ZeeOSix
I just did the CLB install a few weeks ago on my 02 Zee. Not many miles on it, so the risk factor was a little lower, but figured I better do it soon before I get "bit".
For you guys who have CLB kits sitting around in the box ... go do it, only takes 30 ~ 60 min depending on how fast you work. Once in, you won't have to think about it anymore.
Old Aug 14, 2007 | 06:18 PM
Bigstik's Avatar
Bigstik
I bought my Z used. how can I tell if the mod was already done??
Old Aug 14, 2007 | 06:30 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Look for the little black box under the driver's side knee bolster.
Old Aug 14, 2007 | 07:23 PM
ZeeOSix's Avatar
ZeeOSix
An easier way is to listen carefully when you shut the car off and remove the key. If there is a CLB installed, you will hear nothing. If there is not a CLB installed, you will hear a buzz sound for a second or two right after pulling out the key.
Old Aug 14, 2007 | 08:17 PM
Tact's Avatar
Tact
I guess I've had the CLB in for so long I forgot about that.
Old Aug 15, 2007 | 08:31 AM
Bigstik's Avatar
Bigstik
So i definetly need to spend the $50 and install a CLB before I get stranded somewhere, or the misses does.
Old Aug 15, 2007 | 10:12 AM
MiamiCowboy's Avatar
MiamiCowboy
I actually purchased the CLB before I took delivery of my car. Too many horror stories about the issue to take a chance in my opinion. In the end nobody's steering column is locked whether you do the CLB or the GM recall.
Old Aug 15, 2007 | 07:19 PM
ZeeOSix's Avatar
ZeeOSix
I've heard way too many horror stories about the GM column lock recall fix.
Consensus from the members here would be to buy the aftermarket CLB and install it instead of letting GM "try" to fix it with their messed up recall.
Old Aug 16, 2007 | 11:12 AM
Z06David's Avatar
Z06David
Is it the same thing when I put the key in and turn it? I hear a little buzz right before I start it.
To Finally installed a CLB
