Please help
Old Aug 13, 2007 | 02:38 PM
RUNNINGMAN 1's Avatar
RUNNINGMAN 1
Default Please help
The window rattle on the drivers door is driving me nuts the door closes fine with window up but when down rattles Itook the door panel off and don,t see any loose nuts but you can take top of window and it has way too much play in it it will rattle when moved back and forth.
Any suggestions
Old Oct 27, 2007 | 12:54 PM
hayman's Avatar
hayman
Having the same problem.
ANYONE?
Old Oct 27, 2007 | 12:59 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I think most rattle,
Mine do.
Old Oct 27, 2007 | 01:00 PM
ZeroHer0's Avatar
ZeroHer0
is there any difference when the window is up or down? i have seen the window glass causing a rattle when out of adjustment. make sure the glass is tight but not too much or you will cause wear on your regulator.
Old Oct 27, 2007 | 01:05 PM
2KFRC5's Avatar
2KFRC5
Maybe this? http://forums.corvetteforum.com/show...=window+rattle
To Please help
