Rough idle, P0113 and P1111 codes
Old Aug 13, 2007 | 08:05 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Rough idle, P0113 and P1111 codes
Thanks VetteDrmr for the help and fix.
Changed out the IAT pigtail, $20.00, and everything's AOK.
Old Aug 14, 2007 | 01:17 PM
omarcoolguy's Avatar
omarcoolguy
can u give me details i have the same prob
Old Sep 18, 2007 | 02:26 PM
thabeast's Avatar
thabeast
anyone know what he did to fix it?!
Old Sep 18, 2007 | 02:55 PM
IIXLR8's Avatar
IIXLR8
No , but I'm under the assumption that he changed the sensor that plugs into the side of the air bridge, which will make the car idle and run like crap , if it goes bad
Yes...I looked up the code and it's the intake air temperature sensor.
It's a sensor which plugs into the air bridge on the drivers side, all of which is connected to the mass air sensor on the front part of the bridge.
You clip it and rewire it in.
Old Sep 18, 2007 | 03:47 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I had the same code and bought a new sensor. that didn't fix it. I than replaced the pigtail that goes to it and that fixed it. It is a little sensor that goes into the drivers side of the air bridge
To Rough idle, P0113 and P1111 codes
