i posted last week that the plastic border around my hud area warped...now my question..is it covered by my gm warranty or am i just sol and buy a dash mat cover?
While under the GM OEM 3/36k warranty I was able to have the radio bezel replaced twice due to warping. If you've got the GMPP extended warranty I don't believe trim is covered.
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Not worth messing with the warranty anyway (even if it is covered). And certainly not worth it to try to cover up. The new bezel is only about $125 shipped from Gene Culley. Takes less than an hour to change (the first time, then only 30 minutes).
Make sure you can't "fix" it though. I've heard there are some screws inside that will adjust the dash to fit the bezel. Not sure though (although I should be since I've had mine off to replace the stereo, shame on me).
