Overheating
Old Aug 17, 2007 | 06:43 AM
RJP51's Avatar
RJP51
Default Overheating
Greetings forum,
On the way home from work last night my 97 C-5 water temp shot up to 250 degrees. I checked for radiator obstruction, antifreez level, etc. Antifreeze level was a little low so I topped it off. Went to work this am and it hit 250 again. Does this sound like a thermostat that just decided to quit opening? Hoses and cap appear to be fine. Thanks in advance for any help.
Rob
Old Aug 17, 2007 | 07:13 AM
The Punisher's Avatar
The Punisher
Originally Posted by RJP51
Greetings forum,
Rob
How old is the anti-freeze ?
Old Aug 17, 2007 | 07:31 AM
Buckskinner's Avatar
Buckskinner
Default fans
do it sound like yer coolin fans is commin on when she git ta bout 230?
might check under hood fuse an relay box. a 97 ye might have a relay stuck, an tha coolin fan circuit go thu bout three relays afore it git ta ground.
Old Aug 17, 2007 | 07:33 AM
beav626's Avatar
beav626
Check under the car for any leaks that may appear from a small crack in the reservoir...
Old Aug 17, 2007 | 07:40 AM
travelingypsye's Avatar
travelingypsye
Try turning on the air......that will cause the fans to kick on. If that lowers the temp, time to change & flush the system. I don't know why but some cars need flushed a lot sooner than others. Just a guess....
Old Aug 17, 2007 | 10:30 AM
RJP51's Avatar
RJP51
Default overheating...
bump,
The antifreeze is about 2 yrs old, no cracks in resevior, no leaks, heater on for 10 minutes doesn't help. Fans coming on at about 220.....
Tks again in advance
Old Aug 17, 2007 | 10:59 AM
Buckskinner
Default thermostat
thermostat or radiator cloged
Old Aug 17, 2007 | 11:44 AM
4THTOY's Avatar
4THTOY
I had this happen once, I turned on the HEATER to 90, yes it got hot in the car, but it did lower the temp real fast as the coolant travels throught the heater, after a few mins I turned off the heater and things were fine, a trick I learned from my Dad a long time ago
Old Aug 17, 2007 | 12:28 PM
RJP51's Avatar
RJP51
Default overheating
I had the heater on for 10 minutes this morning. Didn't make a difference. Still thinking a non opening thermostat.
Old Aug 17, 2007 | 12:57 PM
geerp12's Avatar
geerp12
Sounds to me like a thermostat, and I wouldn't keep running the water temp up to 250 degree's!!
Old Aug 20, 2007 | 06:31 AM
RJP51's Avatar
RJP51
Default overheating
I changed the thermostat Saturday and now she stays right at 200 degrees. Thanks for the help forum, you guys (and gals) rock!!
Rob
Old Aug 20, 2007 | 07:19 AM
beav626's Avatar
beav626
Glad it worked out
Old Aug 20, 2007 | 11:20 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Wonderful to find a simple fix was in hand and now all is normal again
To Overheating
