Is it ok to keep the vette resting on its lift points on jack stands for the winter (Ohio 4.5-5 Months) and will this cause any suspension or other problems? I read you should not let it set static on the tires all winter (warping I quess).
NO. You do not want your suspension hanging for that long.
You can buy some tire cradles that will keep your tire from flat spotting.
I think at Ecklers or WCC
I overinflated my tires (to about 40psi or so) and my vette sat all winter last year (about 4 months) with no problems, the tires werent even flat spotted and the suspension is fine...
flatspotting is not the issue with modern tires that it was with nylon cords.
If you are concerned; pump up your tires to the maximum on the sidewall ( ONLY for storage)
IF you are really concerned; by a sheet of extruded styrofoam insulation from Lowes or Home Depot. Cut it into 4 and rest the car with one tire on top of each piece. The styrofoam with partially deform and conform to the shape of the tire, distributing the load over a larger area. That is basically what tire cradles do. The styrofoam is exempt from Corvette tax and can be re-used year after year.
From past experience on storing other vehicles in the winter(don't have a Vette...yet), I usually overinflate tires by 15 psi and have had no problems. Of course I'm usually too eager for that first drive and forget to let air out, a little note on the seat cured that. I wouldn't leave the tires on bare concrete though. I usually put a sheet of plastic under the whole car, including tires to prevent moisture. Or at least put a sheet of wood under each tire.
I always use a battery tender. On cars in the past I always removed the battery for the winter and kept it on a tender. For future knowledge though are you able to do that with a C5 or will it mess anything up disconnecting the battery?
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
It is the middle of August - the temperatures here in Arizona are hovering around 110 degrees. I heard today on the radio that we have experienced 25 days of 110+ this summer, and there is over a month to go for the all time record of 28 days......and you are asking for tips on winter storage?
Anyway - here's a very thorough article that should answer all of your questions - click here!
storage? surely ye jest. no way, can't imagin being without it fer two days much less all winter
Buck...not all of them live here in Texas with us and they don't get to drive theirs year 'round like we do...some only drive theirs like 3-4 months out of the WHOLE year. Actually, it's OK...we'll go buy their C6's a few years from now with less than 10k miles on them, it's a secret 'beat the depreciation' trick. Burrrrrr...it's going to be a cold winter, I can already feel it in my bones...'whoever' has my future C6 Z-06, treat it nice and keep it warm, I'll come get her in a few years...oh yeah, don't be driving her either!!
When I put mine away for winter, I put down carpet squares under the tires, inflate them a little higher than normal, put some Sta-Bil in the gas and hook up a Battery Tender Plus to the battery.
I then put a cover on it and there it sits. Haven't had any problems using that procedure.
I either put the vettes up on the pads and remove the rim/tires ( as per GM recomendation). Bag the tires with a dessicant bag and vertically stack ( dry location/ inside).
If not I will inflate the tires to the max side wall pressure ( 44psi) and position the car tires on 18"x18" flat 1/2" nylon plates ( to keep the moisture from the concrete from the tire contact patch).
Fill my fuel tank, add fuel stabilizer.
Fill my windshield washer with a winter formula ( didn't do that one year,oooppps)
Check the coolant for temperature protect.
Add dessicant bags to the interior for absorbing moisture.
R&R oil and filter
Disconnect the battery and connect a 1 amp battery tender.
Finally I cover the cars.
Here in the mountains of central Oregon at 4000ft it gets -20 below.
Besides half the nights a year are below freezing to boot.
