Can't clear codes
Old Aug 18, 2007 | 12:36 PM
HisandHerZ06's Avatar
HisandHerZ06
Default Can't clear codes
I just installed a lid for my blackwing and in doing so, when I put my temp guage back in, I had it turned the wrong way. I popped it back out, turned it the correct way and still only show 69 degrees. I ran the diag and code B0333 with both History and current come up, I then try to hit the reset and it "beeps" but still says 1 code (it won't clear the code), how can I clear it? I doubt I damaged it, and I doubt it went out the same exact time I touched it, so I just assume if I get it to reset it will start working again.
TY
Old Aug 18, 2007 | 12:56 PM
vette1111's Avatar
vette1111
http://www.corvettedoctor.com/2004_DTC_Codes.html
Old Aug 18, 2007 | 01:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
For whatever reason, that temp sensor circuit is open therefore the BCM is generating the current B0333 code on you. If it was working before, then look at the physical connection to the sensor. Somewhere, that circuit opened up and you will continue to receive that code till the circuit works normally.
Old Aug 18, 2007 | 02:14 PM
HisandHerZ06
Originally Posted by vette1111
Thx for the link, but as stated above, I can't clear it by hitting reset!
Old Aug 18, 2007 | 02:20 PM
HisandHerZ06
Ah, I kind of understand what you are saying, but I think I am even more confused now...... I understand that you are saying even when I hit reset, the error is there a split second later so it shows up again.
To Can't clear codes
