drone noise
Old Aug 19, 2007 | 11:06 AM
gizmominou's Avatar
gizmominou
Default drone noise
just bought a 2002 z06 and it as xr-1 longtube and a borla exhaust, it sounds perfect but there is a drone noise around the 2000rpm, maybe it is a stupid question but i am trying to learn as much as i can about my car. Is it normal? thanks
Old Aug 19, 2007 | 11:13 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Normal - yep.
If it is bothersome to the point of irritation; get a trunk partition (available from many Forum Vendors, do a search) or install insulation (see tech assistance, or search Mike Mercury).
Old Aug 19, 2007 | 11:16 AM
Z06ster's Avatar
Z06ster
Based upon the setup you described, the drone sounds normal. I presume you have Borla Stingers. Borla Stingers have drone. Now, with headers, that drone is only amplified. If you don't like the drone (as I do), switch out your catback. That is, you can keep the headers, but replace the Borla Stingers. I had Borla Stingers and switched to Corsa Pace Car. I have headers and there is virtually no drone... I love it.
Old Aug 19, 2007 | 11:54 AM
csexton's Avatar
csexton
Switched to pace cars this spring
Chuck
Old Aug 19, 2007 | 12:06 PM
hotrod03's Avatar
hotrod03
Put Ti's back on, it will cut out 90% of the drone
Old Aug 19, 2007 | 12:13 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
f-it, turn up the radio
Old Aug 19, 2007 | 12:35 PM
jzemo's Avatar
jzemo
normal with that set up
Old Aug 19, 2007 | 01:34 PM
rudyarias's Avatar
rudyarias
The drone was not bad with the stock manifold, x-pipe set up. After my header, x-pipe install. it got so annoying after that I took my stingers off and used my Titanium exhaust
Old Aug 19, 2007 | 02:48 PM
silverstreak01's Avatar
silverstreak01
who cares it's a Performance Sportscar enjoy
Old Aug 19, 2007 | 08:56 PM
RonJ's Avatar
RonJ
I have Borla's on my car, they drone a bit around 15/1600 rpm but I don't mind it.
HOWEVER - I put a Corsa Pace Car cat back on a friends car a couple days back, I haven't had a chance to drive it but he tells me there is no drone at all at any speed!!
Myself, I'll take the drone and the excellent sound of the Borla's!!
RonJ ...
Old Aug 19, 2007 | 09:02 PM
lil vette's Avatar
lil vette
i have the drone too. Been thinking of putting, baffles in pipe.
http://www.jegs.com/webapp/wcs/store...97835_-1_10265
Anyone have any thoughts on this idea?
Old Aug 19, 2007 | 09:22 PM
If you are not running an X-pipe, you might want to give one a try. My exhaust had a terrible drone at about those rpms and after I installed an X-pipe, I'd say 95% of it went away.
Old Aug 20, 2007 | 07:52 AM
gizmominou's Avatar
gizmominou
Default thanks
thank you everybody for your input, i like the drone noise the car does, but if it is normal i can live with it.
Old Aug 20, 2007 | 09:36 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Borla's do sound good and if you like the drone then I would keep them, but if you get tired of them another vote for the Corsa Pace Cars
To drone noise
