Speed limiter on C5....??
Old Aug 20, 2007 | 12:09 PM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
Default Speed limiter on C5....??
I had the opportunity to run the vette on an approved speedway the other day. My 99 Vert is bone stock. The fastest top speed I could achieve was 146mph and at that point it seemed to be limited and actually started to decrease in speed. I though top speed in the C5 was up near 170 mph.... Is there a factory governer installed?
Old Aug 20, 2007 | 12:23 PM
Toms2001PewterC5's Avatar
Toms2001PewterC5
Old Aug 20, 2007 | 12:38 PM
omarcoolguy's Avatar
omarcoolguy
u should be over 155 at least i got mine up to 168 and ran out of road.....i mean "track".....are u sure ur not the one slowing the car down....lol
Old Aug 20, 2007 | 12:52 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
is your vette a 6sp or an A4. if a 6sp then you should of stayed in 5th to get a higher speed
Old Aug 20, 2007 | 01:43 PM
joshscalf's Avatar
joshscalf
Huh...sounds wierd. I got mine up to 146 before I ran out of room and mine was still pulling like crazy. Didn't have the windows down, did ya?
Old Aug 20, 2007 | 01:51 PM
There is no speed limiter on the C5.
Old Aug 20, 2007 | 01:52 PM
Zeek's Avatar
Zeek
That is what I did wrong....It is a 6spd and I did run it up in sixth gear... I never figured to leave it in 5th....I ran it up a second time and it would get to 146 and stop pulling and then the speed actually started dropping...and yes...I had my foot in it all the way....Next time Ill try not shifting into 6th...Thanks for the tip Zilla!...
Old Aug 20, 2007 | 01:54 PM
Zeek's Avatar
Zeek
Maybe I should have put the top up first!!!!......
Old Aug 20, 2007 | 02:00 PM
Z06Electron's Avatar
Z06Electron
5th is the top speed gear, 6th is for gas mileage
Old Aug 20, 2007 | 05:13 PM
Zilla's Avatar
Zilla
I will email you the address where you can send me the cheque
Old Aug 20, 2007 | 05:37 PM
ALVETTE00's Avatar
ALVETTE00
Do the A4 and M6 top out at the same speed in stock config?
I've seen magazines publish a top speed of 175 for the C5?
Old Aug 20, 2007 | 05:47 PM
fmuto42's Avatar
fmuto42
Top speed for me....163mph still with engine left, just no more "track"... Comm. Edition 6 speed with windows up and roof on! What a screamer!!!!!!!! I love this car soooooo much!!!!! My heart does as well, gets the blood and adrenaline goin good!!!!!!!
Old Aug 20, 2007 | 06:24 PM
c4cruiser's Avatar
c4cruiser
The A4 and MN6 cars have very close to the same top end speeds. Either should be capable of around 175 in stock trim.
There is no speed governor but I think there is a fuel cutoff somewhere above 6000 RPM simply to save the motor from over-revving damage.
Old Aug 20, 2007 | 06:38 PM
vetterlatethannever's Avatar
vetterlatethannever
Gonna try my hand at the Texas Mile soon, I don't think I can top it out in a mile though. At the local high speed straight 'track' I have been to 181, little scary when you are there, gotta be scarier for the 'Busa going 186 'before' me though
Old Aug 20, 2007 | 06:39 PM
tellefan's Avatar
tellefan
There is something very special about the CE's. I love mine also. David
Old Aug 20, 2007 | 09:14 PM
Zeek's Avatar
Zeek
I dont understand why, with enough track, you wouldnt get a higher speed in 6th than 5th? I hate to sound dumb...but can someone explain this to me....??:o
Old Aug 20, 2007 | 09:40 PM
RonJ's Avatar
RonJ
But, isn't the engine rpm limited in any given gear by the computer? Like you can't over-rev it unless you gear down two gears by accident. Same result as a speed limiter. For a given rear end ratio you are only going to go so fast.
I think I once saw a chart showing a theoretical 158 mph top speed with a stock 6 speed C5 coupe before the engine is cut back.
RonJ ...
To Speed limiter on C5....??
Old Aug 20, 2007 | 09:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You're correct for all practical purposes...but the PCM will limit it to 255mph.
Best of luck achieving that.
Old Aug 20, 2007 | 10:33 PM
LV_2_XLR8's Avatar
LV_2_XLR8
Not exactly true. When I installed my Maggie, Lingenfelter accidently left one of the zeros off the speed sensor multiplier when they wrote the program in my 2000. The speedometer was reading 200 MPH when I was actually only going 20 MPH. As soon as I hit 200 on the speedometer, the computer shut down the injectors and the motor immediately died. It did this time after time. Needless to say, this was a bit embarrassing when I took it for the test drive. I felt like I was driving a bucking bronco!
Old Aug 20, 2007 | 10:49 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Originally Posted by LV_2_XLR8
Not exactly true.
No, what I stated was exactly true. If you want to go faster than 255mph, you won't be doing it with a GM PCM.
You CAN set the PCM limit to anything (less than that) if you want, in fact you can even create a valet mode and limit your car to 20 mph if you'd like (or mistype)...but that does not disregard the fact you won't be going over 255 on a stock PCM.
