need help programing key fob
Old Aug 21, 2007 | 12:03 PM
engr246's Avatar
engr246
Cruising
Default need help programing key fob
Hi,need help on how to program/train my key fob for 99 c-5 or where to find info!!
thanks
Old Aug 21, 2007 | 12:23 PM
leave it to beaver's Avatar
leave it to beaver
http://forums.corvetteforum.com/show....php?t=1781632
the search button is your friend.
Old Aug 21, 2007 | 12:28 PM
03whitecoupe's Avatar
03whitecoupe
Try this:
To match transmitters to your vehicle:
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver
Information Center (DIC) by pressing the
RESET button.
3. Press the OPTIONS button on the DIC several times
until the blank page is displayed, then press and hold
the RESET button for two seconds.
4. When the message FOB TRAINING is displayed,
push the RESET button once. The message
HOLD LK + UNLK 1ST FOB in the DIC will
be displayed.
5. Press and hold the LOCK and UNLOCK buttons on
the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned (matched), the DIC
will display FOB LEARNED and then prompt you
to learn the next transmitter.
7. Repeat Steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if:
 You don’t program any transmitters for two minutes.
 You take the key out of the ignition.
 You have programmed three transmitters.
Battery Replacement
Under normal use, the battery in your key fob
transmitter should last about 18 months.
You can tell the battery is weak if the transmitter won’t
work at the normal range in any location. If you have to
get close to your vehicle before the transmitter works,
it’s probably time to change the battery.
NOTICE:
When replacing the battery, use care not to
touch any of the circuitry. Static from your
body transferred to these surfaces may damage
the transmitter.
Old Aug 21, 2007 | 12:30 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
engr246's Avatar
engr246
Cruising
thanks much
Old Aug 21, 2007 | 12:34 PM
R Devil's Avatar
R Devil
Sure a lot of fob problems lately.
Old Aug 21, 2007 | 01:29 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by MIKE-C5
That is because you are a post *****
To need help programing key fob
