I used a cheap air compressor line with a bend at the end that I bought at Harbor Freight for something like $4.95. Between the radiator and the condensor blowing the rocks back out the front.
Also, when you are in the heat, run the AC. That will keep the fans on therefore the car will run cooler. Up in Victorville at this time of the year, you need the AC anyway. I know, I lived there for 5 years long ago. I'm down the hill from you now.
Yeah, reverse blow the radiator, clean the intake, and
then if it continues hot reprogram the fan settings.
That's a lot cheaper than what I found, but this thing does a lot more. Kinda expensive for a one time use though. I guess I could have guys come over and use it on their own C5's for a small fee though.
