Stealership
Old Aug 21, 2007 | 10:28 PM
sacstyl's Avatar
sacstyl
Default Stealership
Can u believe they want 225.00 for a set of plugs installed. Is this Corvette tax or is it California tax.
Old Aug 21, 2007 | 10:31 PM
moserbe's Avatar
moserbe
Both! WTH do they charge for labor per hour?
Old Aug 21, 2007 | 10:40 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
What type of plugs? and labor/hr must be . I'm not very mechanical, but could learn to be with the info here. Search is your friend, use it and buy an extra tool or two and you will be a happy camper, with more money for mods.
Old Aug 21, 2007 | 10:52 PM
sacstyl's Avatar
sacstyl
What really suprised me is that 2 years ago it was 75.00.
Old Aug 21, 2007 | 10:57 PM
rcs128's Avatar
rcs128
I dunno... I'd never accuse a dealer of doing a service for a really great price, but $225 for a set of Corvette plugs actually doesn't seem that outrageous for a dealer. Probably $50 for the parts and 1.5 book hours of labor.
I don't understand why people get upset about paying people to jobs they don't have the time/skill/tools to do themselves.
Old Aug 22, 2007 | 07:39 AM
TLewis4095's Avatar
TLewis4095
After you try it yourself you will be happy to pay it And if you had a C4, a wire & plug change is like a major overhaul! (almost)
Old Aug 22, 2007 | 08:29 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
you can take it anyplace else and get it done for half that or do it yourself for less than $50
Old Aug 22, 2007 | 08:44 AM
R Devil's Avatar
R Devil
Good point
Old Aug 22, 2007 | 08:46 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
That's the truth........lemme tell you about my '89 And god forbid an injector or 2 go bad
Old Aug 22, 2007 | 08:57 AM
81c3's Avatar
81c3
Thats too high, but you did go to a dealer! You can DIY in about an hour, going slowly......its a pretty straightforward job.
I'm having a hard time figuring out where $225. came from though. Even if they charge you a mark-up on the plugs, say $10.ea, and an hour labor @$70./hr, I come up with $150.???
Old Aug 22, 2007 | 09:43 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
$70.00????? I wish,try $95.00 here
Old Aug 22, 2007 | 10:13 AM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I would bet that $70/hour doesn't come close. Probably more like $90-100 in CA.
That rate seems a little high, but not totally out of line. Probably books at 1.5 hours + $4-6 each for premium plugs. You also have taxes, shop supplies, etc. A good mechanic can probably do it a little quicker than the book, but that's where shops make money.
You might check if the rate is for book time or actual time. In my bike shop we base a quote on the recommended book time, and actually quote it as "not to exceed" a certain amount. If the mechanic finishes early, we only charge the actual time (quote 4 hours, but charge 3 hours, for example). If the job goes over, we only charge the quoted amount unless there is some underlying reason we didn't know about (He worked on it himself and screwed it up, etc). If it takes 5 hours and we quoted 4, so be it. My mechanics don't work straight commission, but many shops do, so you will probably pay the straght book hours, which are usually a little high for routine maintenence items.
Old Aug 22, 2007 | 10:20 AM
Ishams00vette's Avatar
Ishams00vette
We charge much more then that for every vehicle..... Well for a complete tune up.
Old Aug 22, 2007 | 10:59 AM
lil vette's Avatar
lil vette
I didn't have any problems at all changing plugs in my C4 everything went smoooothly & changed valve cover gaskets, although one side was a bummer, changing the valve cover gasket.
To Stealership
