competition mode
Old Aug 23, 2007 | 11:29 AM
blackwraith's Avatar
blackwraith
Default competition mode
i have tried to put my 2000 into competition mode with no success. the manual says hold down traction control for 5 seconds or more and the display light should go off, never happens. my buddys 2002's display changes to "competition mode". the ignition is on and the car is not moving. can anyone help? thanks andy
Old Aug 23, 2007 | 11:31 AM
Z06Electron's Avatar
Z06Electron
I'm not 100% sure, but this may not have been an option on all 2000's. Can someone chime in here, I seem to recall that the traction assist changed at some point.
Old Aug 23, 2007 | 11:32 AM
gpracer1's Avatar
gpracer1
You might not have it. Check the glove box for the RPO code. I cant remember off the top of my head which one it is. Someone will chime in. It was an option from 98-00. 01 and up it is standard.
Old Aug 23, 2007 | 11:37 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Requires the active handling system which was a $500 add on for the 2000 model year........
Old Aug 23, 2007 | 11:41 AM
C6NRED's Avatar
C6NRED
When you say the "ignition is on"....is the car running? Try starting the car, putting it in gear and then doing it without moving.........and yes, the active handling option is, I think, needed ...........
David A's Avatar
David A
In 2000 you had to order the Z51 Performance Handling Package to get it.
Old Aug 23, 2007 | 11:49 AM
jrpedraza's Avatar
jrpedraza
This probably won't help, especially if you do not have the active handling option, but my '04 takes longer than five seconds to go into 'competition mode'; it takes closer to six or seven seconds and the car has to be running. On mine, I can enter 'competition mode' with the car stopped or running.
JR
Old Aug 23, 2007 | 11:51 AM
HummelS's Avatar
HummelS
No - you had to order RPO JL4, Active Handling. As stated in an earlier post, check the codes on the sticker in the glovebox. If JL4 is not listed, you don't have the Active Handling option.
Old Aug 23, 2007 | 12:09 PM
blackwraith
thanks everyone. yes the car was stopped and running. i no i do not have active handling or the z51 pkg. oh well, i appreciate the feedback, andy
Old Aug 23, 2007 | 12:32 PM
stod16's Avatar
stod16
my car does not have the active handeling and its a 99 if you hold the button down for 5-10 seconds it shows up on the display where the odometer would read out
Old Aug 23, 2007 | 08:21 PM
David A's Avatar
David A
You are absolutely right, I stand corrected.
Old Aug 23, 2007 | 08:26 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
With what he said
COMPETETIVE DRIVING mode, means Traction Control OFF, Active Handling ON, SO obviously if your car is not equipped with A/H, you will never find COMPETETIVE DRIVING mode
To competition mode
