[Z06] fuel filter in tank??
Old Aug 24, 2007 | 11:58 PM
orangejuice's Avatar
orangejuice
Default fuel filter in tank??
Well my car is acting up again, I have been checking the grounds that I can find, I am wondering about the fuel filter being in the tank, my car has a 02/03 build date. Had the car up i n the air and didn't see a filter by the tranny sooo, how hard is it to change??
Old Aug 25, 2007 | 05:21 AM
lar66BB's Avatar
lar66BB
Default fuel filter
I haven't looked for my 04 yet. But the 01 was on the drivers side
back of the rear wheel. Hard to see between the muffler and
the quarter panel.
Old Aug 25, 2007 | 07:23 AM
MIKER's Avatar
MIKER
I was under the impression that the fuel filter/regulator was located on the frame rail, under the drivers seat, up 'til 2003.5. From 2003.5 forward the filter/regulator was located inside of the left fuel tank.
Old Aug 25, 2007 | 11:49 AM
orangejuice
mine is new enuff its in the tank, think I will suck the tank dry, get some sea foam and see if it will clean out the filter. I am not sure what else to try, I am getting no codes. It will sit and idle sometimes, other times it will die. If this doesn't work I will have to try a new pump I suppose, but once they quit they seem to do it all at once. Maybe kwik trip will pay for it, I am sure this is from there crappy gas lol
Old Aug 25, 2007 | 02:00 PM
TheDVS1's Avatar
TheDVS1
Redline Total Fuel System Cleaner works very well for keeping the system nice n'clean. I use a full bottle every oil change, and then a few ounces every fill-up. Pep Boys stocks it.
Old Aug 25, 2007 | 02:35 PM
orangejuice
was just out driving it, I am now thinking it is electrical because it somesimes will cutout for a split secend even when I am getting on it hard. I suppose I need to figure out which ground is for the ecu and injectors and clean it. It seems to run fine and pull as hard as normal. I suppose the main ground to the frame from the battery is a good place to start. I have to get to a bachler party so I won't get to it today. Another thing is its won't do it all the time and there is no pattern to when it does it. I suppose another thing to check is all the coil wires ect.
To fuel filter in tank??
