Ash Tray Cover - Spring
Old Aug 25, 2007 | 06:49 PM
mmaynard's Avatar
mmaynard
Default Ash Tray Cover - Spring
The door that hides the ash tray had never closed firmly on my 2001 vert. When I installed the ipod2car I discovered the spring has slipped out of position. I replaced it and the outter door worked fine, for a while. Now the spring seems to have slipped off again. Is there a replacement that works better? I have looked at several vendors websites and cannot find an aftermarket replacement. Any ideas?
Old Aug 25, 2007 | 07:04 PM
jjmoberg's Avatar
jjmoberg
Default Do what I did
If you can get the outer door spring to work right again take the ashtray spring out and then cut out the ashtray door all together. I never smoke or open that door at all so I don't need the ashtray in the first place, and now the outer door looks perfect.
