Headlight question...
Old Aug 26, 2007 | 06:46 AM
4SFED Z's Avatar
4SFED Z
Default Headlight question...
The plug on the headlight bezel, the one you need to remove to adjust your lights....do you have a special way of securing them? I put mine back in, correctly, but it flew off when I was driving at high speeds. Got another plug, just wondering if anyone went an extra step to make sure the POS doesnt come off.
Old Aug 26, 2007 | 06:51 AM
jdmvette's Avatar
jdmvette
Night Owl for life
glue.
whenever i needed to adjust my headlights i just removed the 3 screws and pull the bezel off.
Old Aug 26, 2007 | 07:52 AM
Corvette00Car's Avatar
Corvette00Car
I appologize if this is no answer but I found that twisting the plug into place is sort of strange because it seems like you almost have to break it before it snaps into place. I use a quarter with pliers.
Old Aug 26, 2007 | 09:49 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Sounds like you have the earlier style push plugs. If you "upgrade" to a later model plastic surround, the plugs twist and lock into place. Probably the best option is to get these.
Old Aug 26, 2007 | 12:02 PM
jdmvette's Avatar
jdmvette
Night Owl for life
his -02z has the lockers.
To Headlight question...
