Lighting - High Beam Adapter
Old Aug 26, 2007 | 07:45 AM
Corvette00Car's Avatar
Corvette00Car
Default Lighting - High Beam Adapter
I recall a few years ago there was a vendor who had a plug and play wiring harnis adapter (just a wired connection to the + Battery post with male and female connnections to the wiring to and at the bulbs, all 3 each side) that would keep the low beam and driving lights on when putting on the high beams. Does anyone remember who that was?
Old Aug 26, 2007 | 08:53 AM
Pres712's Avatar
Pres712
Default Painless P/N 30802
I google searched the company and got right to their website. It costs about $28.00 and was really easy to attach. All the wires are right under the battery and fuse box. BUT, I never was able to figured out how to wire the fogs so they stay on all the time. But the hi's are now on with the low's. Too bad I can't get the fogs to stay on all the time (when the headlights are on).
Old Aug 26, 2007 | 09:20 AM
Corvette00Car
Ok you got my attention. Do you remember the name of the vendor you did the google search on or what terms you used to search. I sure would appreciate it.
Rich
PS: DUH - Painless P/N 30802 LOL I never read the subject line. Thanks.
PSS: Nope not plug and play enough. It requires cutting wires or worse use of crimp connectors. I want to plug into the existing lines either at the bulbs or at other connectors already available.
Old Aug 27, 2007 | 08:21 AM
Pres712's Avatar
Pres712
Rich
Sorry; that's the only one I know but it really isn't hard. Find the correct wires and just use crimp connectors, couldn't be easier? Took about an hour. If I didn't have to screw around with the fogs it would have taken less time.
To Lighting - High Beam Adapter
