My 03 vette is about a month old and I am still waiting for the owner's manual, which was ordered. My question is, can the twilight sentinel be turned off, and if so, how do you do it? Thanks
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
if you are in Canada no ... it's a Canadian law for them to be on all the time . maybe you can find a dealer that will turn off the z49 option with a techII . but I do not think you will get a dealer to do it >
thanks for the replys. I thought it was only the daytime running lights that are required in Canada. I tried resetting the twilight sentinel in the options menu, but nothing happens. It appears to be locked.
All you need to do is take out the #44 relay that is located in the fuse box in the passenger footwell. I have had mine out since 2002, everything works fine, you just have to put your headlights on and off manually.
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
the reason I know this is I have a candian 2000 coupe ... my vette tech turned it off but I am in the USA !
Opps no longer on NCM's site.
That does sound a bit silly you can't turn sentinel off, sentinel has to do with turning on/off the headlights under certain light conditions. The feature is not related to DRLs. Is everyone talking about the same lights, etc.?
