Console hinge help, please.
Old Aug 29, 2007 | 07:39 PM
silver z's Avatar
silver z
Default Console hinge help, please.
How difficult is it to replace the console hinge? The top looks easy enough, but how do you get the bottom of the hinge attached?
Thanks for the help.
Old Aug 29, 2007 | 07:44 PM
moserbe's Avatar
moserbe
Mind if I ask why you want to change it?
Old Aug 29, 2007 | 08:04 PM
Oldvetter's Avatar
Oldvetter
Oil all the hinge pins, it will work MUCH better.
Old Aug 29, 2007 | 08:18 PM
Janster's Avatar
Janster
I dunno about his console....but mine doesn't flip up like they're supposed to.
After we bought the vette - we thought it was kinda hard to open. Our nephew has an 02 and he showed us this quick touch flip method to open it on his. Ours doesn't do it. It just barely pivots off the side and you can't even open it the whole way. Something is messed up with it (hinge). I haven't looked at it closely enough to take notice what's broken.
One of these days...we'll dive into it. But...got the exhaust and clear corners coming first.
Old Aug 29, 2007 | 08:28 PM
ScottJ97's Avatar
ScottJ97
Put some bicycle chain oil (Tri-Flow is what I used) and it will work great.
Old Aug 29, 2007 | 08:31 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
This is a common problem. The hinge is a two stage affair. Oil it up and it should work fine.
Old Aug 29, 2007 | 08:40 PM
steve8's Avatar
steve8
Try a shot of wd-40.
Old Aug 29, 2007 | 08:44 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Lubrication won't work if it's busted. Mine was missing two of the rivets that keep the little arms together on the hinge. Bought a used hinge from C5R 427.
To get it apart, you have to pull the console out. There's two nuts hidden under plastic caps towards the back (under the lid) and another two hidden under the plastic piece the traction control button is in. That piece will pry straight up...just held in with clips. You may want to undo the wiring clip for the gas door switch. Four small nuts hold the hinge onto the console from underneath.
Shouldn't take more than 10 minutes to swap it out.
Old Aug 30, 2007 | 09:42 AM
silver z's Avatar
silver z
Default console
Thanks for the help RJ1AZ. The console rivets are broken, so I need to replace the hinge.
Old Oct 9, 2007 | 10:05 AM
Janster's Avatar
Janster
One of my hinge things is broken on mine....oil won't help.
Anyone know where to get one of these cheaper than $48.20 (quoted from dealer)??
Old Oct 9, 2007 | 10:18 AM
LoneStarFRC's Avatar
LoneStarFRC
GM #10268321 Call 1-800-234-5284 and ask for Bob in parts.
HTH
Old Oct 9, 2007 | 10:47 AM
Junkman2008's Avatar
Junkman2008
If it was me, I'd buy one of these custom jobs for $60 bucks. Pretty sweet for the price.
http://www.augerresources.com/c5armrest.htm
Old Oct 9, 2007 | 10:48 AM
Janster's Avatar
Janster
HTH
Very very cool! Thankyou!
Ordered a hinge!
Bob's da man!!
I actually ordered a lock mechanism also - the little metal flap on the key hole is broken off inside.
Old Oct 9, 2007 | 12:09 PM
LoneStarFRC
Ordered a hinge!
Bob's da man!!
Old Oct 9, 2007 | 12:11 PM
z06Bigbird's Avatar
z06Bigbird
Go to burger joint and let some grease drip on hinge.
Old Oct 9, 2007 | 12:28 PM
LoneStarFRC
That material looks nice too.
Old Nov 24, 2007 | 10:29 AM
Janster's Avatar
Janster
HTH
Bump for Bob!! Thanks again!
It's been a long time - but I was going through my old e-mails and thought I'd update.
I took the locking mechanism to WIZARD lock locally and had them key the lock for me. THat was about $25. To install - we took the center console completely out - made it much easier to work on. While we had it out, we installed the hinge also. Everything works great.
To Console hinge help, please.
Old Nov 24, 2007 | 10:54 AM
LoneStarFRC
Excellent!
GTH
Old Nov 24, 2007 | 11:17 AM
4 KRUSIN's Avatar
4 KRUSIN
Wow! Thanks for the tip.
I didn't know it was a 2 stage hinge because mine has only opened on the first stage since I got the car. I just put some WD on it and Presto! It actually opens all the way. And I thought it was the only design flaw of the car. Now its perfect.
Old Nov 24, 2007 | 01:16 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Its not a design FLAW, it was built that way by design to allow the driver to reach into the console, open it up to the first stage, take out whatever and close it with an open cockpit car. It will keep whatever is inside from blowing out. Some owners keep papers and such in the console.
