Custom headliner, whatcha think?
Old Sep 2, 2007 | 05:15 PM
Black$heep's Avatar
Black$heep
Default Custom headliner, whatcha think?(Pics)
I made this custom head liner a few years ago and then changed it out. I was thinking about making another one.
Whatcha think?
You can scroll down to post #7 for step on how to do one yourself or follow link.
http://forums.corvetteforum.com/show...74&postcount=7
Old Sep 2, 2007 | 05:34 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
I like it, although I'd do mine in black. Care to share how you made it? Might make for a good winter time project.
Old Sep 2, 2007 | 05:51 PM
R Devil's Avatar
R Devil
Old Sep 2, 2007 | 10:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is a pretty cool looking headliner
Old Sep 2, 2007 | 10:41 PM
Bob CTS's Avatar
Bob CTS
I like it.
Old Sep 2, 2007 | 10:52 PM
Looks very nice. Would like to hear more about it.
Old Sep 3, 2007 | 04:27 PM
Black$heep's Avatar
Black$heep
That is a bad pic.(it is black , just bad lighting in the pic.)
List of stuff:
1.Corvette jpg. on transparency paper(printed mine on my inkjetprinter) I'll update this later with the jpeg, don't have it at work)
2."Closed cell" foam sheet.http://www.yourautotrim.com/sculptingfoam.html
3. Cloth or Vinyl head liner material. http://www.yourautotrim.com/auheclvifa.html
4.Spray adhesive. http://www.yourautotrim.com/instabond.html
5. Thin board or extra vinyl piece for base.
6.Rubber roller or something to press out the shape you want.(nothing sharpe)
7.Heat gun or hair dryer(assists with cure time in the tight corners)
I took a corvette emblem jpg.(thanks to a corvetteforum member-??), printed it on transparency paper, and projected it on the wall in the garage using an overhead projector. I adjusted the distance of the projector from the wall to get the right size.Then, I tacked the closed cell foam sheet to the wall and traced the image with a sharpy.
Then cut out the shape you traced and make sure to only remove the pieces you don't want.After cutting, you should be left with the shape you want to stick out. Now, you need to make the base for the headlineer:either use a thin board or a piece of vinyl. I used the old head liner to trace out the shape of the base. The first one I made, I used a thin board for the base and vinyl for the shape.(You'll have to have some heavy duty double sided tape to stick it to you roof.) Later I made one using the vinyl as the base and the head liner material to hold my shape.(seemed to be lighter)
Find the right location and glue the emblem/shape where you want it on the base.*Be sure not to put it upside down*
Now spray the base and emblem with the adhesive and roll the vinyl or head liner material over it. Start pressing the vinyl/head liner material down around the emblem/shape. Some spots may require more force/time to cure. After it cures, spray the back all the way around the edges and rap the material over the edges for a clean look.
This was my first one (I used to much glue) and it didn't look as smoothas later ones.
After letting it cure, you can double side tape it to the roof panel. here are some pics of the first one I did using vinyl.
Here are a couple of pics of one I did using the vinyl for the base and head liner material for the covering. They look a little blue in the pic becuase OF the flash, but they are black.
I hope this helps. If you have any questions feel free to ask. I'll try to help as much as I can.
Old Sep 3, 2007 | 04:53 PM
ledsnake's Avatar
ledsnake
[/QUOTE]
If I had a painted top I would love to have that it is
Old Sep 3, 2007 | 06:45 PM
Patches's Avatar
Patches
Nice job! Looks like you did your rear compartment cover as well.
Old Sep 4, 2007 | 12:07 AM
Black$heep's Avatar
Black$heep
Yep, sure did.
Old Sep 4, 2007 | 12:08 AM
jrose7004's Avatar
jrose7004
I like it!
Old Sep 4, 2007 | 08:40 AM
istsme98's Avatar
istsme98
Old Sep 4, 2007 | 08:52 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Looks great!
Old Sep 4, 2007 | 09:05 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Very talented!
Old Sep 4, 2007 | 09:10 AM
mike348's Avatar
mike348
Looks very good.
Old Sep 4, 2007 | 09:16 AM
goody03's Avatar
goody03
damn good work
Old Sep 4, 2007 | 09:39 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
like to do it in a C6
To Custom headliner, whatcha think?
Old Sep 4, 2007 | 09:49 AM
sneakelman's Avatar
sneakelman
Great DIY mod! Takes some serious patience to pull off work like that.
Old Sep 4, 2007 | 10:19 AM
Black$heep's Avatar
Black$heep
Yeah, I'd love to. I have to buy a C6 first
Old Sep 4, 2007 | 10:21 AM
DRKMATTER's Avatar
DRKMATTER
St. Jude Donor '09-'10
BadAZZ!!!
