Nose Mask
Old Sep 4, 2007 | 08:36 PM
hotozz's Avatar
hotozz
4th Gear
Default Nose Mask
Looking For Some Help Picking Out A Mask
Like Make, How It Attaches,need To See Front Tag Etc.
Have Ordered 2 Sending Them Back, 1 Was A Covercraft, The Other Some Ez Mask From Eckers
Dano
Old Sep 4, 2007 | 08:46 PM
moserbe's Avatar
moserbe
I have and would recommend the GM bra. Easy to put on and looks good.
Old Sep 4, 2007 | 09:08 PM
hotwheels57's Avatar
hotwheels57
SPEED LINGERIE, warranted for life, comes in colors, unique mounting system that "allows" up to 150 mph w/o flapping, triple layer construction for protection. Matching mirror covers are optional.
They're expensive and a little hard to install the first time, after that they're a simple R&R.
Old Sep 4, 2007 | 09:17 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default GM Bra
I like the GM Bra and it installs and removes easy. I loaned it to another Corvette Forum member and he liked it too. If I remember correctly they are a lot less money than the Speed Lingerie brand. I have seen those and I am sure they are worth the money. I have had other Corvette Cruise members remark how nice my Speedway white looked and nary an ill remark about the simple black GM Bra.
Old Sep 4, 2007 | 09:18 PM
TraceZ's Avatar
TraceZ
Have you considered getting the nose covered in 3M paint protector film? InvisibleMask sells some nice pre-cut pieces that simply laminate over your paint creating a nearly invisible bug and stone guard.
2000 CHEVROLET CORVETTE: BUMPER KIT
Part Number: CHV00497B - $173.85
Old Sep 4, 2007 | 09:20 PM
VLVETTE's Avatar
VLVETTE
and it is cheap under $100
Old Sep 4, 2007 | 09:21 PM
RedRckC5's Avatar
RedRckC5
GM bra and way cheaper.
Old Sep 5, 2007 | 06:13 AM
hotozz's Avatar
hotozz
4th Gear
I Saw 1 At The Gm Lot
It Had Snaps In The Fender Well
Thats What I Want
Is It The Gm One
Old Sep 5, 2007 | 08:22 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Thats What I Want
Is It The Gm One
You can't beat the GM bra for the price and durability.
Old Sep 5, 2007 | 10:01 AM
I too would recommend the GM bra. Once you intall the 7 snaps, putting the bra on and taking it off takes only about 2-3 minutes. Never had a problem with it damaging the paint and it protects the front end very well. It also has a clear section to see at least a portion of the front plate.
Old Sep 5, 2007 | 12:15 PM
rrichar2591's Avatar
rrichar2591
Mine cost about 80 dollars and I use it just for road trips. The install was very easy and it's quick to put on and take off. I like the tight fit which prevents paint damage. If you do a search you can find instructions to install. Use the marine snaps instead of the screws included with the kit and the install will go even easier. Good luck.
To Nose Mask
