low coolant warning
Old Sep 4, 2007 | 10:29 PM
mattkilla97whitec5's Avatar
mattkilla97whitec5
Default low coolant warning
everytime i get into my car is says i have low coolant when i know i do not. i replaced my waterpump and ever since then it comes up saying i have low coolent. my overflow is still full and my engine is running fine, the thermo works just fine too. is there a quick fix to this annoying problem?
Old Sep 5, 2007 | 10:59 AM
SilvaDragon's Avatar
SilvaDragon
The level sensor is in the overflow tank. You can try unplugging
and plugging in the connector, you could also pull and drain the
overflow tank and ensure that the float for the sensor isn't
stuck. Failing that, you'll probably want to replace it.
Old Sep 5, 2007 | 01:40 PM
cenzo's Avatar
cenzo
A $7 bottle of Redine Water Wetter solved the problem for me. Give it a try.
Old Sep 5, 2007 | 03:06 PM
mattkilla97whitec5
yeah, i had already put a redline waterwetter in a week ago. ill unplug and plug back. thanks
Old Sep 5, 2007 | 06:27 PM
Oldvetter's Avatar
Oldvetter
It is your sensor in your tank, it can not be replaced seperately, you must buy the whole tank. You might be able to re-position it, here is the TSB:
Document ID# 640586
1997 Chevrolet/Geo Corvette
Engine Low Coolant Light Comes On (Inspect Rad. Surge Tank, Replace/Reposition) #99-06-02-016 - (Sep 28, 1999)
Engine Low Coolant Light Comes On At Start-Up (Inspect for 2nd Design Radiator Surge Tank and Replace/Reposition)
1997-1999 Chevrolet Corvette
1997 Models Built Prior to VIN Breakpoint V5104277
This bulletin is being revised to add the 1999 model year and change the part number identification procedure. Please discard Corporate Bulletin Number 83-62-11 (Section 6 -- Engine)
Condition
Some customers may comment that the "low coolant" light comes on at start-up.
Cause
This condition may be caused due to the low coolant sensor being mounted in the rear of the radiator surge tank. When the vehicle is parked with the front lower than the rear, the coolant settles in the front half of the surge tank and with the switch in the rear of the tank, the switch float may be low enough to trigger the light. The "low coolant" light may come on if:
The vehicle is a 1997 model, built before VIN V5104277, with the old design radiator surge tank.
The radiator surge tank is improperly installed in the vehicle.
The coolant level in the vehicle coolant system is low.
The float in the tank is sticking.
The coolant level switch connector is improperly connected.
Correction
Caution
With a pressurized cooling system, the coolant temperature in the surge tank can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, fenders, and the person removing the cap. Serious bodily injury may result.
For 1997 vehicles built prior to VIN breakpoint V5104277, replace the radiator surge tank and inspect for an out of position wiring harness under the tank. To repair the harness, position the harness downward and secure with a tie strap. To determine if the surge tank is of the first or second design, inspect the low coolant switch cavity in the surge tank. If the surge tank cavity extends 16 mm (5/8 in) below the bottom of the surge tank, the tank is of a second design tank. If the cavity is less than 15 mm (19/32 in) replace the tank with P/N 10405218.
For all vehicles, check the level of the tank by viewing the lower mount on the tank. Less than 2 mm (.08 in) (#1) of the mounting slot should be visible above the attaching nut. If the gap is greater than 2 mm (0.08 in), loosen the surge tank and hold in a downward position to achieve less than a 2 mm (0.08 in) gap above the attaching nut. Tighten the bottom nut first, then both top nuts. Tighten
Tighten the nuts to 10N·m (89 lb in).
Verify coolant level in surge tank:
If engine coolant is hot, above 83° C (180° F), fill the coolant surge tank 12 mm (½ in) above the cold indicator mark.
If the engine coolant is at ambient room temperature, fill to the top of the cold indicator mark.
Parts Information
All parts in the GM Parts System since January 1997, and all parts used to manufacture vehicles since January 1997, are of the second design. If a vehicle is one of the 1997 vehicles prior to the serial number breakpoint, you may have to replace the radiator surge tank as described in Step 1, above.
P/N
Descrition
10405218
Tank Assembly, Radiator Surge
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use :
Labor Operation
Description
Labor Time
J3250
Tank, Radiator Coolant Surge - Reposition
0.2 hr
J3250
Tank, Radiator Coolant Surge - R&R
Use published labor operationtime
Add
Reposition Wiring Harness
0.1 hr
Old Sep 5, 2007 | 06:35 PM
Red99FRC's Avatar
Red99FRC
Are you parking with the nose of the car downhill from the rear? If so, it can read low, even though it isn't. I had that happen several times on my '99. Try it on a level spot, or with the nose uphill.
Old Sep 5, 2007 | 06:39 PM
Try the procedure mentioned by Oldvetter. If you still have the message, probably is the sensor itself.
Old Sep 5, 2007 | 10:33 PM
mattkilla97whitec5
it doesnt matter how a park. i had to replace the overflow tank about a year ago and dont want to do it again just because it shouldnt have to be replaced so fast.
To low coolant warning
