Is This Typical?
Old Sep 5, 2007 | 11:03 AM
hayman's Avatar
hayman
Default Is This Typical?
I am a new owner (99 vert Stock). Is it typical while at a stand still, stepping on the accelerator and it take what seems like forever to hear the results from the mufflers (probably at most a second)? Is this because it is all stock or some computer chip setting? Is that what these chips that I see on eBay do?
Bill
Old Sep 5, 2007 | 11:22 AM
02MillenniumVette's Avatar
02MillenniumVette
If you car is completely stock then it is normal. IMO the stock exhaust sounds like crap. You need to chang out your exhaust if you want to hear it or put some headers or a cut out on it. And I dont know of any "chip" that will make your exhaust louder.
Old Sep 5, 2007 | 12:34 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
1. It is because you are stock.
2. It has nothing to do with any "computer settings"
Old Sep 5, 2007 | 12:46 PM
WetteVette's Avatar
WetteVette
Change out your exhaust. It WILL put a smile on your face!
Old Sep 5, 2007 | 12:50 PM
hayman's Avatar
hayman
Guess I should have said throttle response. I have a Borla exhaust so the sound is great.
Old Sep 5, 2007 | 12:54 PM
uracowman's Avatar
uracowman
Bill
By the one second lag I believe you are referring to throttle response.This has nothing to do with your exhaust but is due to that fact that you have an electronic throttle.You can't do anything about the lag.
Old Sep 5, 2007 | 01:39 PM
Cajun99's Avatar
Cajun99
...Is this because it is all stock or some computer chip setting? Is that what these chips that I see on eBay do?
It's because you're stock.
Also for you and any other's "new" to the C5...THERE ARE NO CHIPS TO SET, INSTALL, MODIFY OR REMOVE.
The ECM is programmable.
Old Sep 5, 2007 | 01:43 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Yeah, what Cajun said.
Get a puter tune done and see how your throttle response is. Had mine done by ECS, what a difference! Whole other car.
Old Sep 5, 2007 | 02:32 PM
It's just the stock exhaust - get an aftermarket catback system and enjoy the new sound.
Old Sep 5, 2007 | 05:15 PM
hayman's Avatar
hayman
Old Sep 5, 2007 | 05:24 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I would be willing to wager that you have A4 with a 2.73 gear, worse combo for performance. Change that gear to a 3.42 and put a on your face.
Old Sep 5, 2007 | 05:30 PM
hayman's Avatar
hayman
I have a M6 and I am questioning the throttle response sitting still at a stop light or stop sign. Just revving the throttle. That is the lag time I am referring to. Push the peddle (SITTING STILL) and the time it is pushed till the time it makes the rpms increase.
Old Sep 5, 2007 | 06:56 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
put in a supercharger
To Is This Typical?
