Gear Upgrade?
1. Most importantly, would this invalidate my GMPP Warranty? If so, could I get it done by the stealership (not a good idea, I know) to be covered? I've heard horror stories about stealership installs but is there any other way around the warranty coverage issue?
2. Is this the best way to go as it is a DD and I do a lot of freeway driving and don't want to compromise my MPG too much.
3. Would I have to upgrade my torque converter?
4. What sort of price would I be looking at, for buying the unit and having it installed? Basically an out-the-door price.
The only other mods that I have are Diablo Predator (standard performance tune), Borla Stingers, Borla X-Pipe, K&N dual air intake, high flow MAF and most importantly the performance hood seal
I only really want to increase the acceleration from 0 - 60 and am not interested in increasing top speed. Had a close call with an M3 and wasn't too happy about it
Thanks in advance for all your feedback.
Probably; they're looking for a reason to get out of any free service work. Although the MMWA is supposed to protect you; sadly its only as good as the lawyer you pay to get the rights the MMWA is supposed to give you.
The best way to mod but still retain your warranty is to not make it known.
3.42 = great all around gear
No; you don't have to. But if you ever consider a converter, then this is the time to have it done.
Heres a mild converter that doesn't need an external cooler and is low priced:
http://forums.corvetteforum.com/show....php?t=1715694
As for the gears, 3.90s are the way to go if 0-60 is your focus. I lost only 3 MPG, although I think much of that can be attributed to my right foot exploiting the ridiculous amount of fun provided by the new gears. I did install a 3200 stall and definitely recommend doing it at the same time as the gears, though it is not absolutly necessary. Make sure you get a hardened output shaft installed, as the OEM shaft will not last long with the new gears.
All told, my 3.90s, 3200 stall, and hardened output shaft cost approx $3500, labor included.
Personally, I went with 3.73's and a 3000 stall. I went from high 20's MPG to mid 20's........but passing sure is more fun and so is 0 to 60....
And without driving it ,quite a bit,I doubt they would even have a hunch.
I'd bet you would be ok....Heck, it wouldn't be much different than driving around in "3" all the time rather than "D"
If you broke an output shaft,or torque tube somehow,they might look at the gearing more closely though and may not cover things of this nature
For the most part,my opinion is you should be fine
Car feels much stronger - not sure on my 0 to 60 times, but they have to be better than stock
The only thing is I kind of wish I went with 3.73 gears though.
I went to the 3.42's and man what a difference!
It does not make a difference in the fuel mileage or the RPM's (Well in that it is not huge in the RPM department - what an extra 150 RPM's at 70 MPH!)
What I noticed was a quicker response and harder acceleration on the road as well as on the freeway! One time I thought had I not had the gears it might of been --- well you know!
I say go for it!
You can get a set of used ones like i did for around $500-$600 bucks in the For Sale section here at the forum!
As for the install a shop will probably charge about $300-$400 to do the install!
Just be sure to change the setting to the 3.42's with your handheld tuner before you leave the shop!
Thanks,Matt
and that's the trick you gotta play. Just don't tell any Chevrolet dealership about the mod.
Sure, there's the MMWA. But it's only as good as the lawyer you pay to legally get your rights under the MMWA.... months or years later.
If a dealer wanted to, they could refuse GMPP warranty work on the entire drive-train (including the engine) because of a rear axle upgrade.
Your choice then is to either hire a lawyer, or drive to another GMPP authorized repair shop and hope they won't be azzes like the last place.
