Roll Bar Question
Old Sep 6, 2007 | 10:01 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Roll Bar Question
Guys, look at the picture below, what is the 2 brackets on this Mallet Car ! !
Old Sep 6, 2007 | 10:06 AM
RonVette2's Avatar
RonVette2
I'm just going to take a guess, and say maybe to hold the targa top when placed in the back if it still fits, and you would have to slide in som other kind of bracket to support the top...? Just a thought, I really do not know.
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
it could be for the targa top to rest on since it appears that there are rubber bumper on the bracket
Old Sep 6, 2007 | 11:40 AM
MIKE-C5's Avatar
MIKE-C5
That makes sense ! !
Old Sep 6, 2007 | 11:41 AM
IMXCITD's Avatar
IMXCITD
I really like that bar and the install...very clean!
Old Sep 6, 2007 | 12:14 PM
Craig Wagner's Avatar
Craig Wagner
If that is for the targa top, and it probably makes sense that it is, I wish GM would have found a way to store the top flat like that from the get-go. When you're on a road trip, it's kind of a pain if you want to take the top out because the angle it sits at limits your ability to put luggage underneath the top. This would give you a lot more space under the top (although you'd lose some space due to the rear bracing bars, so it might be a wash).
Old Sep 6, 2007 | 12:18 PM
Dave98's Avatar
Dave98
Just get a convertible and be done with it
Old Sep 6, 2007 | 12:43 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is what I was thinking
Old Sep 6, 2007 | 12:46 PM
SmoothFRC's Avatar
SmoothFRC
maybe bottle mounts?
does look like stops for the top though..
Old Sep 6, 2007 | 04:52 PM
b98's Avatar
b98
What ever it is, you need it. Buy it and let us know how much HP. it added.
Old Sep 6, 2007 | 06:57 PM
edcmat-l1's Avatar
edcmat-l1
Yep. For the top. Notice that the nubs are gone from the floor.
The new mounts are where the studs will go. The top will sit flat, with area under it for luggage.
The only thing I dont like about it is the carpet is cut out to the edge.
When we do em, we set the assembly in, cut the carpet around the bar, slide it up the bar, then weld it to the frame, slide the carpet down, and viola, no cuts in the carpet!
Other than that, real nice piece.
I really like how its bent in the middle of the hoop, to better fit the top of the car. Thats nice. I may have to try that......
To Roll Bar Question
