You posted a 228/222 for the second choice. I take it you meant a 228/332. I run a cam with those specs, it idles at 750 RPMs, drives well in traffic and sounds really good. If you are planning on more mods in the future, I would go with the larger cam.
See you have a stall on your car. I would go with a england green kit. As i dont have the cash to do the stall at the moment i may end up going with something like a mti stealth cam and ls6 heads. It should still get me to my 400rwhp goal
That's my ultimate goal too: 400 rwhp, I can't do heads and a cam due to a lack of funds, so I'm going with a cam, but I think I'm going to be a bit shy, right now it's at 325 rwhp.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by 1998whitecoupe-a4
Of these 2 choices, which one would work better with stock heads and an A-4 with a 3200 stall?
224/224 or 228/222
Sorry, don't know much about cams, but these were recommended.
If you have a stall, you can go with a much larger cam than the one you mentioned. As far as "driveability" and "street manners" are concerned - it's all in tune.
