ABSFixer does it again
Old Sep 6, 2007 | 09:31 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Default ABSFixer does it again
Well I just recieved my repaired EBCM module from Brandon (aka ABSfixer) installed it and ... after resetting a few codes all my error codes have gone away.
Thanks also to Trussme for his step by step instructions.
C1214 HC is gone
Old Sep 7, 2007 | 10:10 AM
JROW's Avatar
JROW
what did this cost if you don't mind me asking?
Old Sep 7, 2007 | 01:15 PM
Waytofastvette2006's Avatar
Waytofastvette2006
Just had mine fixed $150 bucks + 7 in shipping
Had it at the dealer they told me 1600 bucks to fix this problem hahahah
Old Sep 7, 2007 | 06:39 PM
Allzwell's Avatar
Allzwell
$150 plus whatever shipping mode that you would like.
It's pretty straightforward removal and the re-install is a breeze once you know where the 6 screws came from.
Old Sep 7, 2007 | 09:12 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
hmmm mines throwin several codes, all history and 2 have HC which i would assume means history/current, and if i can recall correctly that is definitely one of them.. and my act hndl warming up/service vehicle message comes up everytime i drive the car.. maybe i should look into this..
Old Sep 8, 2007 | 12:09 AM
5W0P3's Avatar
5W0P3
This is ME on ABSFixer.com's website. He met me in a lowes parkinglot on my way back to Dallas in Springfield Missouri. Took pics on how to swap it out. (i swapped it in the parkinglot)
http://www.absfixer.com/how_do_i_remove.php
Old Sep 8, 2007 | 08:12 PM
hatcht's Avatar
hatcht
8th Gear
Default New to Forum
Hi, I am new to the forum, I was searching the web to see if I could find out what was wrong with my 2001 Vette, it only has 39000, miles on it, and now I have a Engine Check Lite , that stays on all the time, and the act hndl warming up, comes and ( sometimes) it will go off, and I alerts me that it is warmed up, and sometimes it never goes off.
Nothing unusual has been done to the car... no maintance.. it does need an oil change,
I would appreciate any "Try This"... I have not had a code reader hooked up, I should get one, but dont know a good one to buy.
Thanks in advance for any help, I will give the instrustions to my husband...
Old Sep 9, 2007 | 12:31 PM
5W0P3's Avatar
5W0P3
Your car has a built in code reader...
get in the car, close the doors, turn the ignition on, push "reset" to clear any messages. Then, with "options" held down, push "fuel" 4 times. That puts the car into diagnostic mode.
IT will start going through all the codes, i forget which buttons let you go up and down in the list, but E/M will exit the mode, and Reset will clear any codes.
You'll see codes with a letter than numbers "C1214 CH" , the "C" at the end means its currently happening, and the "H" just means its happened in the history of X number of ignition cycles (i think). Some codes may only have "H", might mean they're intermittent.
Hope this helps and welcome to the forum
To ABSFixer does it again
